Monster MotorsportEM Tuning
    A3_Turbo's Avatar
    Swaying towards IHI....
    Jul 2006
    Virginia water, surrey
    1,441
    Question Emmisions problems please help!
    Right to cut the story short basically the CO2 emmisoons on my car are way too high they were off the scale.
    A "legit" MOT wouldnt work as the emmsions were way too high so i had to have a more "freindly" MOT. Any-way MOT is fine now.
    It made me think why are the emmisions so high? All it has is a 4 bar FBR And a full miltek with sports cat mated to a custom 3 inch oval.
    It does drink a fair but of fuel recently too just wondered what the cause could be? Do i get it on a rolling road or what?
    Jason
    A3 1.8TS
    K03S,Pro Alloy FMIC, Neuspeed TIP, Forge 007P,Jabba Stage 2, BMC CDA, Turbo Back Miltek,H&R Cup Kit,H&R Arb's,18" Cup 3's Wrapped in Parada Spec 2's, Facelifted, 10k Hids, Dewipered, Debadged,S3 Interior, S3 Rear bumper, S4 Front bumper, Brembo's, Momo Team, LCR Splitter.
    May 2003
    Reading
    705
    Have you scanned it with VAGCOM, and faults found?
    03 Ebony black S3, Dieselgeek short shift, its started..
    A3_Turbo's Avatar
    Jul 2006
    1,441
    Well no faults were found when it was at jabba having the work done. Might be worth having it scanned again?
    J
    A3 1.8TS
    Feb 2004
    2,036
    what p[art of the emmissions were high, CO or Hydrocarbons.
    If it was hydrocarbons it could be burning some oil, if its co, its just the idel mix wrong! either needs the map tweaked or there is another fault causing high co. Usually a mapper will confirm the idel co as part fo the map, so have you changed anything post map (ie a new mod) or had any other probs since mappping?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Could be a lazy lambda probe.
    A3_Turbo's Avatar
    Jul 2006
    1,441
    No not changed anything since, the MOT guy rteckons it was very rich but can it be that rich running at 1.5 bar of boost?
    Jabba did the stage 2 map but i guess id have to take it back to them to tweak the map?
    Jabba are so far away from me thats the thing,
    Jason
    A3 1.8TS
