Monster MotorsportEM Tuning
Results 1 to 7 of 7
    Sep 2007
    161
    S3 Miss Fire...Finally took it to a VAG specialist
    As some of you may already know my S3 has been misfiring lately. I changed the coil packs and spark plugs (common problems), it stopped miss firing but then came back. This didn't solve the problem.
    Took it into a mechanic today they stuck the vag com in and found the faults that we already know about e.g. misfiring cylinders disconnected MAF disconnected injectors etc etc so they just reseted it.
    We checked the spark plugs again, it looked like 1 and 4 had never been used where as 2 and 3 were a bit black as in it had been sparking.
    They then went on to doing a compression test in the cylinders where the spark plugs live and found that all 4 were very low on compression.
    I have been advised to leave it there and they will perform some other checks, which is to check the timing belt which may be causing to run like how it is if that doesn't work then a compression leakage check.
    They told me the worst possible scenario might be that they may need to take the head off to discover faulty valves or a knackard cylinder head which may repairing or replacing. Could it be possible that valves 1 and 4 are gone thats why spark plugs 1 and 4 still look new?
    Hopefully its just a timing issue if not then maybe a valve or two has gone, if it needs a new cylinder head it can be very costly i am not looking forward to it if it is.
    Looks like i wont be able to up to gti international tomorrow but ill still going ill just jump in with one of my mates.
    I'll update you guys soon hopefully with some good news.
    Tek
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,911
    Thumbs up
    Tek look out for me I'll show you the wheel and have a chat about this problem,big ugly bloke with S3 in the fastest colour
    jamieface's Avatar
    the only S3 in the villiage
    Oct 2007
    Cheltenhamshire
    198
    Good luck with the car mate hope all is well and your not gonna be out of pocket too much
    Feb 2004
    2,036
    If timing belt was out it shoold throw a fault code.
    Sep 2007
    161
    The car is sorted now. Two pipes were replaced which were slit, wish i spotted them earlier but they were in a hard to reach place.
    s3_tny's Avatar
    Jul 2005
    essex
    92
    glad its all sorted now mate
    atleast you can go and enjoy your S3 ownership properly now
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Glad to hear you finally got it sorted mate.
    2007 A3 TDI 170 S Line
    Sold - 2002 S3
