EM TuningVolks Autos
Results 1 to 27 of 27
    Sep 2007
    161
    4 Spark Plugs & 4 Coil Packs Later...Car Still Stuttering
    Car was running fine except the odd jerk in the idle also noticed the smoke out the tail pipe looked a bit cloudy but don't think its a head gasket problem that wouldn't cause jerking... 5 miles later the car started jerking/misfiring again, sounded like the cogs in the gear box were all out of sync and it kept clanking...not to sure how to explain it.
    Cant believe this is happening after spending 120 on the coils and 50 on spark plugs.
    Need a vag com desperately. My mates cousin works for a VAG specialist and he said he will help on on Saturday to diagnose the problem. Looks like i wont be able to drive my car up to GTi International this weekend.
    I think i've almost ready everything single thread on ASN on coil packs sparks and misfiring but cant seem to work out what is up with mine.
    Anything else i can add to this check list?
    • Spark Plugs - Changed these twise
    • Coil Packs - Changed these also
    • MAF - disconnected this problem still there
    • TIP (top right near air box)- Squeezed this seems to be soft but not soft as the big pipe thats located on the bottom left hand side.
    • Checked for split corroded wires/pipes (could there be any underneath that i am missing?)
    Anything else i might have missed out guys?
    sorry for the long winded story.
    thanks
    T
    wibble111's Avatar
    needs to scratch the itch
    Nov 2006
    derbyshire
    829
    Not sure if it will be much help but i had a missfire problem on my 1.8ts,
    took it to my local vag specialist and it turned out to be the ignition control module, iirc about 150 fitted.
    Hopefully you'll get it sorted soon.
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    If I was you I would take it to a local specialist mate, probably cheaper in the long run to diagnose the problem.
    jesters3's Avatar
    The Shire's
    1,516
    You might as well do a throttle body alingment. Disconnect the battery for 10mins, reset via VAGCOM (ideally the preffered method but as I see you can't) or open door turn on ignition wait a few clicks turn off and then start her up.
    Had a similar issue with my BAM engine. Anyways whereabouts are you based? Also any lights come up?
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    jesters3's Avatar
    The Shire's
    1,516
    Oh and just to add you might as well clean the TB first and then do the TBA.
    This is my thread on the TB issue I had
    Throttle Body issue
    Jester
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    You have to get VAG-COM or similar on it. It might be something like a bad crankshaft sensor or cam position sensor.
    Interesting that the fault disappears after messing with things. Heat related? How are the wires around the coil packs? I've seen these crack in the past. Any hissing from the engine bay like a big air leak?
    May be fueling, but again you'd need to read error codes. Lambda issue should allow the car to run albeit down on power.
    Sep 2007
    161
    I might try doing the TBA and the TB how long will this take?
    My engine gets really hot is all s3's like this?
    Wires round the coil packs are fine. No hissing at all.
    Need to wait till Saturday to get her checked out on my mates computer...might need to drive down there hope i dont cause any more problems.
    themanthatcan's Avatar
    Mar 2008
    Southampton
    665
    With respect mate, stop pissing about and get it down a garage. I've lost track of how many people have already advised you to do this but you still insist on driving it around and splashing out money on possible fixes. Get it plugged into VAG-Com and find out the error codes. That should tell you EXACTLY what is up and you can then purchase the parts required or get it booked into a garage.
    2001 S3 AMK in black - Ambient lighting kit and Aero wipers.
    Is it wrong to love your car more than your girlfriend? - When you no longer have a girlfriend it's fine!
    jesters3's Avatar
    The Shire's
    1,516
    Cleaning the TB is an hour job, 5 mins taking it off, 25 cleaning it and 25 to let it dry and 5 to put back on.
    1. Remove lower boost hose and push to one side
    2. Unclip the connector underneath the TB
    3. Unclip the hose on top
    4. The TB is held on by 4 bolts (2 on top, 2 underneath), these can be taken off using a 5mm Allen Key
    5. Remove TB and be careful not to rip the paper gasket.
    6. Holding it with the electrics above, spray in carb cleaner and wipe clean it out
    7. Be gentle opening the butterfly valve and clean around using cotton buds
    8. On drying one good tip is to get some newspaper and cut it into strips and feed it through the gaps beteween the valve and the housing as this is where the most fluid gets caught.
    9. Let it dry thoroughly and put the TB back on
    10. Do the TBA
    11. Cross your fingers and start her up!
    BTW you can't do a TBA until all DTC's are cleared from the system so either way you need to VAG-COM it....
    Jester
    Sep 2007
    161
    cheers for all the help lads...guess i need to vag com it.
    might need to do it sooner than Saturday any good specialists near north London?
    Mar 2008
    Southampton
    665
    When following jester's advice on doing removing and cleaning the TB, DO NOT try and move the butterfly valve. It is held in position by a stepper motor and moving the valve may damage the motor. The only time it's ok to move the valve is if you have the older non-DBW engine which has a throttle cable.
    Feb 2004
    2,036
    I think you should have a real careful look at your coilpack and injector wiring. it could be a chaffed wire shorting to earth, or even a broken wiring plug. Get some electrical contact cleaner and clean all the plug terminals. See if ith the motor runnign you can wiggle some wires and get ti to misfire??
    Also, see if you can see which cylinders have the problem, using the plug out method you used before, see which plug is cool or wet if you can.
    Did you use original audi vag coilpacks and MAF?? some of the GSF ones etc are rubbish (a "search" will confrim this!! !!)
    Get it to a local dealer, even VW, I find if you speak nicely to the parts guy you have been getitng all your coilpacks stuff from (hopefully genuine) then he will probly have a quick work and get a tech to bop it onto their diagnostic, it takes about 5 mins and if you have spent fair wedge, they will do it for free! ! !!
    Sep 2007
    161
    I used brand new coil packs and spark plugs from audi main dealers. Ill give the injector wiring a clean.
    the problem is the car is running like a tractor now when switched on, do not want to leave it running for too long let alone drive it to audi main dealer as it sounds as if the bottom of the engine is going to collapse or something it is jerking really bad
    Clach's Avatar
    A3 - 1.8Ts
    Jul 2007
    Oxford
    974
    I am 99% sure it is the injector coils, did we not discuss this before...?
    Turbo Sport, Auto (I know!), A lot of 's -and rising [latest add: Recon'd. tranny] sunk in her since Aug. 07...
    Sep 2007
    161
    injector coils is this not the same thing as coil packs?
    Sep 2007
    161
    if so i have changed all 4
    jamieface's Avatar
    the only S3 in the villiage
    Oct 2007
    Cheltenhamshire
    198
    seriously Tekin get your car down to a specialist you are soon getting to the point where good money will follow bad listen to themanthatcan the guys on here have some bloody good advice i know theyve helped me out loads !!! i had a similar problem and mine turned out to be 2 coil packs and a faulty cam position sensor.
    The one thing you have to remember with a S3 is they are NOT cheap cars to fix and run, the majority of the time they will be faultless but on occasions like this you need a specialist. Best of luck mate hope it does get sorted for inters at the weekend.
    Sep 2007
    161
    Cheers jamie im going to need more than luck to get it sorted before Sunday.
    I have took all the advise on board and thank everyone for helping me but i dont think i will be able to solve this one.
    I am currently seeking a good independent Audi specialist in my area would like to take it in before Saturday ...anyone know of any good ones please let me know.
    thanks
    jamieface's Avatar
    Oct 2007
    Cheltenhamshire
    198
    Where abouts are you ???
    Sep 2007
    161
    North London
    Clach's Avatar
    A3 - 1.8Ts
    Jul 2007
    Oxford
    974
    No, Injector pack, or amplifier are seperate and ignite the coilpacks. Although I notice you have a 2002 S3 so then an amplifier (normally located on the air-intake box) is unlikely to be the problem as i think they incorporated this item into the coilpacks themselves post 2001..apologies for wasting your time their mate...
    May 2008
    Surrey
    59
    Hello mate, I am not sure if anyone has recommended Dean Hill at 4rings but I've been reading through a number of different forums including TT ones and he come highly recommended! and he is mobile!
    Based in Dartford I believe so could be worth a try?
    His number is 07906 5813940, alternatively the email is service@4rings.co.uk.
    Hope you get it sorted ASAP, would also be interested on the cause just in case for future reference.
    May 2008
    Surrey
    59
    FYI, here's the link where i got the contact info from http://www.tt-forum.co.uk/ttforumbbs...+rings&start=0
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    This is a boring thread
    Sep 2007
    161
    I have got a guy (cousins mate) coming down on sat with another sort of vag com he will find out the problem and try fix it on the day, if this fails then i will contact Dean Hill.
    Jambo do you know how much he roughly charges per hour? so i have some sort of idea.
    cheers
    May 2008
    Surrey
    59
    To be honest I havent got a clue how much he charges but I would be inclined to get someone who knows what they're talking about ie. a specialist as many people have said before. Hopefully your cousins mate is a specialist with vagcom.
    Just like to echo Jamieface's comment about the S3 NOT being a cheap car to maintain and run... you really do need specialist kit to diagnose problems on this type of car and swapping parts for trial and error is 9 times out of 10 a very much false economy.
    Anyway as said before good luck and hope you get it sorted soon.
  28. #27
    Sep 2007
    161
    The guy who is going to look at my car works for a firm that specifically deals with VW's and Audi's he works on them on the time...anyway we will see how it goes im sure it will be fine.
    cheers.
