AH FabricationsSky Insurance
Results 1 to 14 of 14
Thread: esp prob.
    Nobiuss_993's Avatar
    Apr 2008
    Belgium
    54
    esp prob.
    Hi,
    my esp jumps on today..
    i don't now what four.
    hope someone has a idea.
    Audi S3 8L 06/2000 APY -> Milltek, FORGE 007p, B&B TIP, BMC CDA, JD-engineering costum chip! 275.4PK & 408NM
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    my esp lights up when i go a bit quick over a pot hole or something due to a wheel being cocked or something but then goes out straight away.But if not id get use vagcom like htc says
    A4 TDI S-LINE
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    when the light comes on, it means your ESP is off.... just in case you didnt know
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    yeah but isnt it meant to flash when its working hard,as when i go over potholes etc and the light flashes i can feel it working,its the same in new trucks i know they are completely different but its the same concept. In Daf trucks (i work on them) when one of the wheels has lost traction the traction control or esp or psm or asr ,etc light comes on its showing the driver that you wheel slip is happening.Or is the audi version different im intrigued.
    A4 TDI S-LINE
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    i know what you mean, the light comes on when it slips..... i had a few instances when i first got mine where the light would come on randomly, i had to stop and restart the car to get it off again...weird...never got to the bottom of it
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Likely to be lateral or longitudinal acceleration sensor - VAG.com will tell you which. They are about 100 each and either behind the glovebox (pre facelift) or under the steering cowl (facelift). DIY replacement if you don't mind scraping your knuckles.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Apr 2008
    Belgium
    54
    i do not know what it is.. i don't have vag.com..
    obd2 tool maybey soon.. will do that the job en tell me what it is?
    i still have power on the wheels, so i think what THC is telling it is.
    The MAF..
    Why me.?.?
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Quote Originally Posted by Nobiuss_993 View Post
    The MAF..
    Why me.?.?
    Without knowing exactly which part/sensor is causing the problem, it'd be difficult to fix as you may end up replacing parts which are working fine.
    If you don't have vag.com or a friend that does it may be worth taking it to the main dealer (they normally charge you for the car to be scanned but at least you would know what's causing your problem).
    Just one more thought - Is it just your esp light that comes on? - I've had a intermittant problem with the lateral acceleration sensor causing both the esp and abs lights to come on and stay on until i restart the car so I'm going to try to clean it at the weekend and i'll see if that fixes it.
    good luck
    Mike
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    Apr 2008
    Belgium
    54
    The ESP light is allways on.
    Is it bad to drive with it?
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    It'll depend on what's causing the esp light to come on
    If it were me, I think I'd go to the main dealers just to be sure, it may turn out to be something small & cheap that's causing it but i'd want to know
    S3 AMK
    Apr 2008
    Belgium
    54
    At last, i read my ecu.
    temperature sensor G262: Signal to low: po118
    Maf: G70: signal to low: po107
    The maf i can fix myself, but the temp. sensor i don't thinks so....
    I think i go to my audi dealer.
    do i have to remove my K&N panel filter?
    Thx
    GreetZz
    S£'s Avatar
    Mar 2008
    Suffolk
    669
    Thx
    GreetZz
    i get the esp light come on randomly sometimes, then when i check the codes it always says maf signal to low and boost to high?? Plus when i unplug the maf the esp light will stay on till i plug it back in again.... Strange!!
    davidhodgkinson's Avatar
    lancashire
    198
    Thx
    GreetZz
    I think G262 is a air vent temperature sensor?
    G62 is one of the engine temperature sensors
    Was A3 1.8Ts
    Now S3
    807
    I would just clear all the codes then wait to see what comes back
    Best way to find out the current problem as previous faults may have been fixed
