Chris NottMonster Motorsport
    Mar 2004
    Liverpool
    140
    Squeaking brakes...
    Hey everyone....
    My brakes sqeak when i apply only a small amount of pressure, but when i push them hard they dont.
    I am presuming that this is due to brake dust, but its so friggin annoying. [img]/ubbthreads/images/graemlins/burningmad.gif[/img]
    Any one know a solution without replacing the pads?? There is loads left on the pads so they arent worn down or anything, they are the originals, my car has only done 10800 miles so far!! [img]/ubbthreads/images/graemlins/grin.gif[/img]
    1,361
    Re: Squeaking brakes...
    The problem you described sounds like it's the usual brake pad squeal which is due to the pad rattling against the caliper housing. Normally people suggest copper grease on the back of the pad, which is effective, but generally only for the short term. The best product I've used has to be Permatex disc brake quiet. If you carry out a search on the stuff you'll find a supplier close by I would of thought.
    Mar 2004
    Liverpool
    140
    Gambba...
    Thanks for the info...
    That stuff looks easy to use, will probably try it!!
    How easy is it to replace the pads?? Any tips or advice anyone?? Any instructions available??
