Chris NottAH Fabrications
Results 1 to 7 of 7
Thread: First Service
    Exeter, Devon
    12
    First Service
    Hi All
    How much would you expect to pay for your first service ?????. My S3 is on the AVS servicing intervals and has done 15k in 21 months.
    Also I've been told that the car needs an oil change at 20k, is this so ????
    Fluff
    S3K
    S3K's Avatar
    Oct 2003
    Now residing in Sheffield!
    147
    Re: First Service
    Mine came to 449.22, it was the first AVS and was at 19,000 miles.
    Heres the breakdown-
    Carry out AVS 180.50
    Brake fluid service 66.50
    Change Haldex oil 38.00
    Sub total on labour 285.00
    Filterelement 13.00
    Screenwash 2.02
    Oil filter 4.00
    Plug 0.60
    Haldex oil 8.55
    Castrol check kit 9.95
    Castrol slx oil 47.30
    Brake fluid 11.88
    Ign coilpack x 4 Free of charge as warranty
    Subtotal parts 97.30
    Got a wash and vacuum and a fat 66.92 VAT added to the total of the two....bumping it up to the 449 mark!
    PaulS3's Avatar
    UK
    1,003
    Re: First Service
    mine was 246 for service and haldex oil, and i supplied the engine oil @ 52 ish.
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Re: First Service
    The old coils will probably have been the old type which were prone to failing. Mine were changed on the warranty as well so I had the new type. When you take yours in ask if you have the new or old type in.
    Mine is a Y 2001 plate-facelift and I needed them changing, especially when one of them went!
    Exeter, Devon
    12
    Re: First Service
    JamS3
    Mines an 02 model.
    Fluff
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Re: First Service
    Have a check on the coils themselves, on the end it should have a letter printed. I think its a I or J which relates to the new revised versions and H is a old version. Or just wait until the car goes in for its service and ask them which ones you have in. If its the old ones then they should replace all four for you free of charge!
    S3K
    S3K's Avatar
    Oct 2003
    147
    Re: First Service
    [ QUOTE ]
    Fluff said:
    Thanks for the replies guys.
    They've quoted me 263 all in, this also includes Haldex change which should be done at 20k (so the dealer said).
    So I think that's a good price [img]/ubbthreads/images/graemlins/smile.gif[/img].
    S 3K,
    Looking at your breakdown, did you ask for these things to be done or are they standard things that get changed on the first service.
    Filterelement 13.00
    Screenwash 2.02
    Oil filter 4.00
    Plug 0.60
    Haldex oil 8.55
    Brake fluid 11.88
    I'm just woundering if I'm going to get any nasty suprises for the dealer.
    Also why did they change Ign coilpack under warranty ???.
    How old is your car ??? Will they need to change mine, do I need to mention it to them ????
    Fluff
    [/ QUOTE ]
    The brake fluid service apparently needs to be done every 2 years which the car is coming up to now, the same goes for the haldex. The check kit i didnt ask for but it includes oil and screenwash and cloths and stuff to keep the car tip top with fluids. The other bits like the oil and filters etc i was expecting to pay on top of the initial labour charge. Looks like you got a good peice. Let us know the outcome. Sorry it took bloomin ages to get back to yah but have been pretty busy [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
