Ok eventually got the car hooked upto vag com heres what came up:
VAG-COM Version: Release 409.1-US
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01: Engine
Controller: 06A 906 019 BS
Component: 1.6l 2V/R4 SIMOS HS3125
Coding: 00011
Shop #: WSC 06435
4 Faults Found:
00537 - Lambda (Oxygen Sensor) Regulation
18-10 - Upper Limit - Intermittent
00533 - Shareware Version. To Decode all DTCs
19-10 - Please Register/Activate - Intermittent
00520 - Shareware Version. To Decode all DTCs
31-10 - Please Register/Activate - Intermittent
00523 - Intake Air Temp Sensor (G42)
30-10 - Open or Short to B+ - Intermittent
Readiness: N/A
Address 03: ABS Brakes
Controller: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 06435
No fault code found.
I cleared these codes and started the car up again and scanned again but it didnt pick any codes up the 2nd time.
The car starts fine, idles fine, revs in neutral fine. Soon as I try to move off the car seems to not want to move and I have to hard accelerate to get it moving to which it then seems to buck/jerk/move back and forward as if the wheels are egg shaped if you know what I mean lol. It still holds the revs and can gain power but still with this bucking movement. Any ideas before I get it picked up by the garage at the end of the week?
