JMB RetrofitsChris Nott
    satanmademedoit's Avatar
    Nov 2007
    Ireland
    98
    Unhappy CO Level High @ Idle?!?
    Hi all,
    Its been a while since i needed some info but alas the time has come again.
    After getting my 01 S3 tested for emmissions it appears that the CO level at idle is 0.8%. The maximum test pass is 0.5%. I have no fault lights on and the car drives great but this is a major problem if I cant get it through the test.
    I'm using octane boost and I'm wondering if this is causing a rich mixture?!
    Has anyone any ideas of how to reduce the CO levels even for long enough to pass the test.
    Your help is very much needed.
    2001 S3 210
    Black
    Forge 007 DV
    Rebuilding Depleted Funds for Remap
    S3 Dave's Avatar
    Now running on Heavy Oil
    Jul 2007
    Middle England
    432
    Stop using your octane boost fill up with 95 ron give it a good blast and try again. Next check all air/oxygen sensors, Worst case cat is breaking down..................
    "Never in the field of human conflict was so much owed by so many to so few"
    Churchill August 20th 1940
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,911
    Goddammit Dave change your avatar!
