JMB RetrofitsSky Insurance
Results 1 to 32 of 32
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    slight sttuter and not gareth gates
    just wondering if something is on its way out
    put my foot down to overtake and the car stuttered then accelerated and stutted again. After Id overtaken the cars I tried again and got one small stutter. Drove steady for 2 miles then she was fine for the blast down the motorway and dual carriageway to work.
    any pointers ... not that ling since I cleaned my DV valve.
    Dodgy fuel ??? as I filled up last night and have done 15 miles since.
    any pointer grateful
    red to red black to black blue to bits
    jesters3's Avatar
    The Shire's
    1,516
    What rpm? Above 4/5000rpm? In some old S3's the TIP collapsed meaning restriction and stuttering happened. Other than that, MAF (take it off), TB (due a clean), DV (put old one back on), N249 (check all is good), Hoses (check all is good), Coil Packs (Vag.com it) and a piece of string!
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    Clach's Avatar
    A3 - 1.8Ts
    Jul 2007
    Oxford
    974
    I would start with the fuel...as I can see garage's trying everything to keep profits up as people cut back from driving...Have you been to the Garage before?
    Turbo Sport, Auto (I know!), A lot of 's -and rising [latest add: Recon'd. tranny] sunk in her since Aug. 07...
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,434
    Sounds like the classic on the way out MAF, do a scan with vagcom to see if anythings logged up.
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    ive had the same problem only yesterday with 1st and 2nd.....Vagged and nothing showing
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    thats me
    Sep 2004
    west yorkshire
    3,762
    the garage is the only one I have used for the last 4 years,
    I don`t have vagcom
    Never had it before so doubt the TIP is colapsing but you never know. 02 plate btw
    might check connection to maf and pipe conecctions there as I did have that out about 8 weeks ago ( only 500 miles ago).
    strange thing is it drove home ok last night ( with a bit of welly) at first it felt like the clutch or esp kicking in but wasn`t that.
    rpm I think was 3-5k wasn`t looking at that while overtaking lol.
    whats the best thing to clean the maf with some electrical degreaser ????
    thats me
    Sep 2004
    west yorkshire
    3,762
    N249 which bit is that ??? and where is it ???? doh should have taken more notice when Ive read about it.
    jesters3's Avatar
    The Shire's
    1,516
    I've got an 02 plate and had to change the TIP as it had a split in it and some of the 1999/2000 were prone to collapsing - only way to check is to get underneath and above and give it a squeeze if it is really really really soft there's your problem
    For the MAF and TB Cleaning check out Cleaning MAF and Throttle Body gives two links to how to's
    Shame you haven't got VAG.COM - Anyone nearby that can check you out?
    Jester
    jesters3's Avatar
    The Shire's
    1,516
    Quote Originally Posted by fingermouse View Post
    Check out DV/N249 help
    It's the bit on top of the block covering coil packs 3 and 4.
    Check out http://www.seatcupra.net/forums/showthread.php?t=42406
    for pics
    Ta
    Jester
    thats me
    Sep 2004
    west yorkshire
    3,762
    ok after a quick look under the hood I founf the Tip top clip slightly loose, tightened and car is worse.
    So cover off at home to find this ...
    and this
    looks like the top of the spark plug is in the coil pack (i am right in saying these are the coil packs ???)
    looks like I need at least 1 spark plug and a coil pack ( they were only changed 13k ago)
    hope this cures the problem its what it feels like a slight missfire if not then Ill have to dig deeper
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    the long metal tubes are indeed coil packs - the one on the left looks absolutely shagged (technical term).
    It also looks like it's been exposed to extreme heat based on the colour of it - the one on the right is how they normall look (well maybe a little bit dirtier than that one).
    At a guess i'd go for the spark plug not being fitted properly and as a result it allowed the detonation heat from the cylinder to get through the small gap and that heat's damaged the coil pack resulting in the cylinder not working as well as it should and your misfire / stutter.
    New packs are about 26 quid from audi or abit less from vag.parts, your probably best off changing all the spark plugs as well just for peace of mind.
    Mike
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    before i even got to the photos i was gonna say coil packs !
    easy sorted ! i would recommend you replace all plugs & packs though.
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    thats me
    Sep 2004
    west yorkshire
    3,762
    which plugs would you recommend ??? and would GSF have the coil packs or is it best just sticking with Audi ???
    got to wait till thursday to sort it as im working today
    thats me
    Sep 2004
    west yorkshire
    3,762
    the burnt coil pack actually cleaned up like new but the end of the sparkplug is stuck in it.
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    for the sake of 26 i'd replace the coil pack using one from audi and bin that damaged one.(might also be worth getting a spare just in case)
    As for plugs - opinions seem to vary, I think audi install bosch ones as standard but you might want to do a search to see what other S3 owners recommend.
    S3 AMK
    Clach's Avatar
    A3 - 1.8Ts
    Jul 2007
    Oxford
    974
    Quote Originally Posted by MikeA3 View Post
    I carry a spare coil pack in the boot...just in case.
    thats me
    Sep 2004
    west yorkshire
    3,762
    i hope you have a 5mm allen key and a 10mm spanner/socket so you can change 3 & 4.
    Clach's Avatar
    A3 - 1.8Ts
    Jul 2007
    Oxford
    974
    Yup, indeed, I often go to and from London to Dundee...Going up there in two weeks actually so an Oil change is due for the 8 hours of high revs...
    Feb 2004
    2,036
    Stick a set of plugs in it quick.
    Is yours remapped. With the heat that has clearly been generated there to discoulour that coilpack, I reckon your plug electrode may be shagged. If it falls apart it could do nasty things inside your motor!
    I just posted on the plug thread about leaving plugs in for long periods!! Regular changing or at least checking and cleaning on turbo cars is a very good idea!
    jesters3's Avatar
    The Shire's
    1,516
    Quote Originally Posted by simch View Post
    Forgive my ignorance - how do you clean a spark plug?
    Jester
    Nov 2005
    UK
    1,688
    speak to vagparts.com for the coil packs their ll send you latest revision i think its R. As for plugs the standard ones should be fine unless you wanna spend a fortune on super ones which wont do anything.
    wanted for 8L S3:
    Milltek system
    Feb 2004
    2,036
    Quote Originally Posted by jesters3 View Post
    Carefully!! A fine wire brush is not too bad, but try not to cause too many scratches on the electrode part.
    I have a special cleaner tool that uses fibreglass fibres to clean them without scratching.
    thats me
    Sep 2004
    west yorkshire
    3,762
    I would use vagparts but i need to sort this quickly and don`t know if I can wait for the postage. bank holiday weekend and all. Audi and GSF are the same price for the coil packs but audi want 11 quid a spark plug ffs.
    thats me
    Sep 2004
    west yorkshire
    3,762
    well new coil pack and a set of plaugs and shes back on song . Think I now have one R coil pack 2 x L and one J. NGK spark plugs with no screw on top so shouldn`t get this problem again.
    Last time I pay someone to service my car the plugs wern`t even in to the correct torque.
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Glad you got it sorted out
    S3 AMK
    thats me
    Sep 2004
    west yorkshire
    3,762
    yup , thanks to all for the help / pointers.
    might look into getting a vagcom setup soon
  28. #27
    jesters3's Avatar
    The Shire's
    1,516
    Nice ops.
    What NGK plugs were they BTW?
    Oh and get the VAG.com best money i've spent on the S3
    Jester
  29. #28
    thats me
    Sep 2004
    west yorkshire
    3,762
    Nice ops.
    ah didn`t look paltinum ones ... Ill have to check the boxes in the garage
  30. #29
    Mar 2007
    Cambs
    471
    How much did this set you back mate? I think I have the exact same thing you have just described!
  31. #30
    thats me
    Sep 2004
    west yorkshire
    3,762
    the coil pack was 25 quid and a set of plugs was 30 quid from GSF. make sure you get the good plugs and don`t be fobbed off with what they are trying to shift at the time.
    oh and genuine audi coil pack, only 25p chaeper than audi but audi plugs are 10 each plus vat
  32. #31
    Wicked666's Avatar
    Feb 2005
    Leeds
    582
    Whats a 'TIP'? Would Vagcom pick up if this was failing?
  33. #32
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    TIP = Turbo Inlet Pipe
