Monster MotorsportVolks Autos
Results 1 to 15 of 15
    Stan1.8T's Avatar
    Dec 2007
    Preston, Lancs
    22
    Temperature and Oil/Oil Filter help
    Hi,
    After a bit of advice please, done a bit of searching, but not really sure.
    1. Right had my A3 1.8T Sport since end of December, but just in the last week or 2 the temp gauge has crept above 90 to around 95. Checked the coolant level and that seems fine.
    What other things could it be? I know there are probably many things, but just the obvious, common ones?
    2. I'm looking to do my first oil change since owning the car, I'm guessing its wise to change the oil filter at the same time too? Thinking of going for this oil and filter combo from Opie. Just wondered if you guys recommend this oil and filter?
    http://www.opieoils.co.uk/p-1163-oil...sp27017fs.aspx
    Thanks!
    h100vw's Avatar
    Aug 2006
    Down South, next stop Antarctica
    215
    Stan, the same thing happened to me last week. After a period of the temp dropping to 70 and back up to 90, it finally overheated.
    I tried a new stat, hoping it had stuck shut. Only 30 dollars, nil fix, had to be the water pump.
    New belt, pump, tensioner and roller just fitted. 4 hours on the drive. Tap Dave up, he has plenty of time on his hands now!!
    Get it looked at soon or check your AA cover.
    Later
    Gavin
    Check this too. http://www.vwwatercooled.org.au/newf...ad.php?t=12492
    May 2003
    Reading
    705
    Has it had the cambelt changed yet? If so was the water pump changed? If not then change both soon.
    03 Ebony black S3, Dieselgeek short shift, its started..
    Jun 2003
    World of my own
    9,813
    Yes, if the water pump is on its way out, it's only a matter of time before it seizes and strips the cambelt taking out most of your 20 valves along the way.
    Alex Turner
    Stan1.8T's Avatar
    Dec 2007
    Preston, Lancs
    22
    According the service book, the cambelt was done at 80K and my car is on 89K. I just emailed the previous owner to see if the waterpump was done at the same time.
    Could it be the thermostat?
    Also has anyone used that oil I linked to?
    Cheers.
    jesters3's Avatar
    The Shire's
    1,516
    1. Temp Sender Change; common fault; 30.00 to sort and 5 mins to do
    2. Thermostat; comes hand in hand with the sender; 30/40 for parts + labour to do it, bit of a bugger to get to IIRC.
    3. On the oil, I hear a few people talk about the Fuchs stuff though I have never used it I still use the Castrol SLX and a standard VAG Oil Filter. Price is good though as always with Opieoils
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    Stan1.8T's Avatar
    Dec 2007
    Preston, Lancs
    22
    Ok the previous owner says the water pump wasn't done
    Its due for its service in 1000mile (my first with the car). Does anyone know the rough cost to get the water pump changed?
    Do you think I should get the service done now and the water pump changed or wait?
    Also whats the cost of a typical service? Or do they vary massively?
    Sorry for all the questions! Help is appreciated!
    Cheers.
    h100vw's Avatar
    Aug 2006
    215
    Stan, got you confused with another Stan I know in Preston.
    http://www.psituning.com/workshop/Workshopnew.html
    Sample prices for water pump and belt changes in the link. Not sure that I'd be that keen to drive to Stoke if the pump is iffy. Mine was boiling up in about 5 miles.
    gavin
    Stan1.8T's Avatar
    Dec 2007
    Preston, Lancs
    22
    Quote Originally Posted by h100vw View Post
    gavin
    Thanks for the link Gavin! Nice website and they seem like a decent place, have you dealt with the them before, are they good? You think its worth traveling the 60 mile, or getting somewhere closer to me. The only place I know is the Audi Dealer about 2 miles away and I'm guessing they will be more pricey.
    jesters3's Avatar
    The Shire's
    1,516
    Audi would charge 99+VAT per hour so at 35+VAT per hour you have saved 60 all ready which would pay for the 60 mile trip! As it's done nearly 90k I would take it to a specialist like PSI
    Jester
    h100vw's Avatar
    Aug 2006
    215
    Quote Originally Posted by Stan1.8T View Post
    Andy, Used to work at Awesome before going it alone. I send my Father in Law there, now that I live in Australia and he lives in Wigan.
    The only concern for me is if the pump quits altogether on the way there, you'll need a tow.
    There is a place in Blackpool that is pretty good but their name escapes me. The fella running the servicing used to be at the VW dealer in Blackpool. His name is Pete.
    Gavin
    Stan1.8T's Avatar
    Dec 2007
    Preston, Lancs
    22
    Cool, cheers for the help! Much appreciated! I will give PSI a call and book my car in I also noticed they do CC remaps which is tempting!
    Stan1.8T's Avatar
    Dec 2007
    Preston, Lancs
    22
    I am just trying to change the Temp Sender, but I can't find the thing!
    http://www.wak-tt.com/tempsensor/tempsensor.htm
    I am using this guide, but I can't seem to find it. Will my sensor be in a different place?
    Anyone help?
    jesters3's Avatar
    The Shire's
    1,516
    have a look on here as well My A3 1.8T Coolant Sensor
    May be lower down
    Jester
    Stan1.8T's Avatar
    Dec 2007
    Preston, Lancs
    22
    Quote Originally Posted by jesters3 View Post
    May be lower down
    Awesome! That guide seems a lot better and some good pictures. I will have another go tomorrow when its light.
    Thanks once again!
