AH FabricationsEM Tuning
Results 1 to 16 of 16
    themanthatcan's Avatar
    Mar 2008
    Southampton
    665
    Great doc on how to data log using Vag-Com
    I found this document while researching data logging in Vag-Com and thought some of you might find it handy
    http://72.232.196.98/~dpham00/gti/va...20Graphing.pdf
    Andy
    2001 S3 AMK in black - Ambient lighting kit and Aero wipers.
    Is it wrong to love your car more than your girlfriend? - When you no longer have a girlfriend it's fine!
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    cheers Andy, theres a lot to read but looks very interesting..........
    Tim
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    jesters3's Avatar
    The Shire's
    1,516
    Good find have a gold star!! I was after that sort of info. As I started to do mine:
    Log Blocks 015 & 016 - To check for bad coils
    Log Block 115 - To see the specified Vs actual boost.
    Log Block 002 - To show air mass from the sensor
    Log Block 032 - To check for a O2 sensor/Throttle Valve (+ =lean & - = rich)
    Log Block 031 - To show lamda reading from O2 Sensor
    Log Block 011 - To log boost pressure (In Excel graph actual/requested boost -vs- rpm )
    In a high gear (4th/5th) give full throttle from 1500-2000 rpm to 3500-4000 rpm
    But you just saved me from trawling all over the place!
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    so how exactly would you do this boost check, look at blocks 011 and boot the car at the stated rev range, then stop and produce the graph? or does vag com log a certain test time range....can you explain what you have done step by step to get the actual boost vs the requested boost
    Mar 2008
    Southampton
    665
    Quote Originally Posted by 1animal1 View Post
    The doc I posted shows you how to do everything matey, including producing the graph in Excel. If you don't have Excel then you can download the OpenOffice suite (http://www.openoffice.org/ - It's free and does everything MS Office does!) and use the Calc application which is their equivalent of Excel.
    Block 115 is the one which logs RPM, Requested (Command) boost and Actual boost. You click Start, do your run (3rd gear, 2k RPM to redline) then click stop. That dumps the data into a CSV file which you open with Excel and use to create a graph.
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    is that with the shareware version?
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    im sure it is, need to check but have played with the blocks before on shareware
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    hmmm, just checked, im running the 3 series edition as the other freewares wont work on my Vista..... and its measuring some things but wont touch blocks 115 without purchase
    Mar 2008
    Southampton
    665
    I've got version 409-1 shareware running fine on Vista. To run the software properly you have to right-click on the Vag-Com icon and choose the "Run as Administrator" option. I had problems with Vag-Com locking up if I didn't do that.
    jesters3's Avatar
    The Shire's
    1,516
    Vag.com is $99 and at the present exchange rate 50. Seriously though invest it in then you can measure to your hearts content plus it is a invaluable tool. TBH it's the best 50 I've spent on my S3.
    Jester
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    cheers Jest
    Andy..... i loaded up the 409 version last night, this allowed me to do the auto search option for faults which the other version didnt...still wouldnt allow blocks 115 though:o/...gonna wipe it off tonight and try again me thinks
    Mar 2008
    Southampton
    665
    Quote Originally Posted by jesters3 View Post
    Don't you also have to purchase a new interface with the latest version of Vag-Com though? I thought the 10 cables off eBay (which most of us have got) only worked with version 409-1 and older?
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    wheres the option to 'run as administrator'...cant seem to find it:o/
    May 2003
    Reading
    705
    Right click the icon, you may need to hold down the left shift key at the sme time
    03 Ebony black S3, Dieselgeek short shift, its started..
    jesters3's Avatar
    The Shire's
    1,516
    Quote Originally Posted by themanthatcan View Post
    I've got a USB Gendan cable with 409.1 on XP Pro. When buying it I had to give them the serial number of the trial copy which they then converted to a full version. But yes I would agree that to run the new version you would require one of their specific cables.
    Jester
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    Quote Originally Posted by j4jon View Post
    nope when holding shift, still only get option like restore and 'about vagcom' and 'exit'....this is on the main screen where you can select auto scan etc
