EM TuningVolks Autos
Page 1 of 2 12 LastLast
Results 1 to 40 of 47
Thread: FMIC design
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    FMIC design
    well i've been a busy boy since that intercooler kit on ebay sold for Ł600+ second hand.
    the first prototype has been fitted but i have had to loose the fogs and side grills. looks pretty good an works well, no more LAG than standard SMIC yet intercooler core has a larger surface and internal capacity.
    I have also had to cut 5mm from the bumper to allow a gap between core and aircon rad.
    pipework has been done in 63mm piping which is the same as standard pipework.
    total cost in man hours and parts Ł265.
    what i proposing to do is if anyone is interested at this point is for Ł350 you would get..
    INTERCOOLER CORE 450x230x70 63mm inlets
    ALL CORE MOUNTING PARTS
    BUMPER BAR (cut) exchanged for your current BUMPER BAR. or extra Ł45 if no exchange.
    ALL SILICON HOSES (USUAL COLOUR CHOICES)
    ALLOY PIPES
    ALL THE HEAVY DUTY JUBILEE CLIPS
    FULL FITTING INSTRUCTIONS
    A couple more pictures...
    the green tape is only colour i had at the time to mount external thermostat
    behind my RS4 bumper which i have fully repaired and removed headlight washers and number plate recess..
    If anyone is interested no let me know!
    or you can wait and i'm going to get the side pipes all made in alloy piping
    bigger cores are also available for extra charge.
    S3 - Gone but not forgotten!
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
    Nice job
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    looks like a good custom jobbie good resale prices to you should do ok out of them im deffinently intersted although want to keep foggies etc
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    If it helps any you dont need to leave a space between the FMIC and Radiator. No-one else does.
    Is that FMIC level?
    <Insert meaningless geeky specs here>
    Jun 2007
    446
    nice one mate. good work, but dosnt look like it sits level with bumper or crash bar?
    SÂŁ's Avatar
    Mar 2008
    Suffolk
    669
    Looks good, but had you been on a session down your local boozer when you leveled it up!!
    I think i would probably be interested in this, i think the Ł800 for a forge kit is a bit pricey!
    Is it the same size as the forge one? and also is there anyway around it to keep the grills and fogs? i think i prefer a subtle stealth look when you can only just see it behind the grill..
    Good work!!!!!!
    Ibzzzzz's Avatar
    Apr 2007
    666
    Alrite mate!? Long time since your car has poped up on here, im sure your getting the original RS4 fog components? that would look the **** man! where is the plate going to go without the recess?
    2006 - A4 - 1997 1.8T 20VS, Full Black Recaro Leathers, Concert, Climate Control, Facelifted, Remus, Front armrest! - Sold
    2007 - A3 20vs -bridge gap motor....
    2008 - Think its time for the Civic Type R.
    2009 - Screw a Type R. Got a VR6 instead (missed even now)
    2011 - Focus St170. < what was i thinking...
    2012 - Lateee 8L S3 with EVERY extra....Broken...other asn members enjoying my parts!
    NOW! - B5 S4 Avant - 2.7 Twin Turbo POWWEERR! WWOOOOOSSSHHH!
    stapo69's Avatar
    All hail the mighty quattro!
    Mar 2007
    966
    Looks good bud. You're still alive then? Do you not answer your phone anymore!?
    MRC-Powerflex-Hotchkis-Porsche-Compomtive-Vredestein-034-JHM-Apikol-EBC-FK-Labree-Vibrant-Recaro
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    its is all level now i swear, it was when it was first fitted.
    i'm gonna put the humber plate in that place just wanted to smooth it out in the first place.
    if i sit the core back and jigly the pipework about a bit i could get the fogs and grills back in.
    sorry been busy with wedding and work has been **** last 2 days!
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    looks really good...... wouldnt wana lose the fogs though.... how much extra work would it take to keep them, pipework wise
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    well i am going to try today.
    sit the core back an inch. just jiggle the pipework round a bit if you were to use smaller tubing it could be achieved easily.
    but i will see today!
    forge use a wider intercooler maybe that is the key to sitting the pipework back enough to refit fogs. but i didn't want to increase the LAG from the spool up so only went with the medium core.
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    I have a massive core and it only drops about 1psi pressure.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Could you flip the cooler unside down and run the pipes closer to the crash bar. You'd need to probably swap the pipe work.
    Just a thought.
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    its not the pressure loss i cared about it was the overall lag.
    anyway good news is i have the all the grills back in and reckon i've cracked it for getting the fogs back in.
    bad news is whilst trying to fit the RS4 bumper again today it cracked again so i through a paddy and have ripped it into 5 pieces! what a waste of money that was!
    Shy19s's Avatar
    Oil running through my veins.
    Apr 2008
    London
    902
    New rule: Dont work on your car when its your time of the month.
    Totally addicted to boost.
    stapo69's Avatar
    Mar 2007
    966
    Now mummy's gotta put all your toys back in the pram!
    Sounds like it's time for a beer!
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Oopsy.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
    Quote Originally Posted by stapo69 View Post
    Deffo millertime
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Quote Originally Posted by sitrials View Post
    Erm, one and the same. If the pressure loss is too great it has to flow more air before the pressure becomes the same as it was before intercooler, hence lag.
    Jaywoo_A3's Avatar
    Audi dead, 2.0T all the way!
    May 2006
    Derbyshire
    509
    Ouch! was just starting to look good aswell and you were doin what i wanted to do with mine getting rid of the numberplate recess.
    BLACK AUDI A4 B7 2.0TDI 140BHP S-LINE AVANT
    RED GOLF MK5 2.0TFSI 253BHP GTI
    BLUE GOLF MK3.5 2.0 110BHP COLOUR CONCEPT CABRIOLET
    May 2003
    Reading
    705
    Great news on the grills and fogs. If you have moved the intercooler back towards the rad, could you install it without cutting the crash bar?
    I'm interested in this if you can get it in with the fogs and grill, and ideally without cutting the crash bar, or do you have any pics on how much of the bar you need to cut away?
    03 Ebony black S3, Dieselgeek short shift, its started..
    jesters3's Avatar
    The Shire's
    1,516
    I thought the Forge Kit comes with a 'pre-cut' crash bar? That said IIRC there was a AS.NET member who DIY his FMIC then got slated for cutting into his crash bar even though Forge do it themselves!
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    im sure Glen said that the Forge item required no cutting of the crash bar.....
    May 2003
    Reading
    705
    IIRC Glen had the Star performance FMIC which didn't require the crash bar to be cut. Although it was mad by forge but to Stars design
    jesters3's Avatar
    The Shire's
    1,516
    Thought I would doublecheck - see pdf http://www.forgemotorsport.co.uk/media/S3FMIC.pdf
    But looking at previous FMIC and with EssThree install you are right no modification made - though it does look shorter than normal.
    Jester
    May 2003
    Reading
    705
    I think I would rather have a slightly smaller FMIC and keep the crash bar intact, than having a huge FMIC and a crash bar that has had all the strength removed.
  28. #27
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    you can fit the core behind the crash bar as is but was very tight this is why i bought the size of core i did to try to not cut the crash bar at all!
    but as this is a prototype and a crash bar fairly inexpensive i thought why not cut it away, after all I know what would need cutting away if i wanted a bigger core!
    as i said above i can supply precut crash bars anyway with exchange for you old one or Ł35 you keep yours uncut! for if you wish to return to standard!
    fitting is pretty much identical to the forge kit moving the horn etc.
    plus using thinner pipework will allow fogs to be fitted.
    dave i know what your saying but i meant was i didn't want a big lump of boost to suddenly wack me back in my seat. although it does anyway with original setup.
    hopefully we will see when car is remapped again but won't be for a month or so yet.
  29. #28
    SÂŁ's Avatar
    Mar 2008
    Suffolk
    669
    Sitrials will actually make much difference being a smaller core than most, yours looks about the same size as the two side mounted ones put together then with thiner pipe work to get the fogs and grill back in is it worth it??
    I'm not slating your work, just don't know much about fitting one!!
  30. #29
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    the core is bigger than standard it may not look it but it is.
  31. #30
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    does the FMIC provide longer intervals of boost..... i assume not as its the cooling that is its objective..... making more use of the boost thats there rather than increasing it....correct me if im wrong
  32. #31
    May 2003
    Reading
    705
    Having a FMIC *may* allow you to run more boost, as the inlet air is cooler so you *could* run more timing before the ecu pulls it back to protect the engine.
    Is that not the case?
  33. #32
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    na i dont wana run more boost.... im fairly certain i understand the use.... it basically allows you to make the most of the boost you already have......
  34. #33
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    holding peak power longer when moving
  35. #34
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    ahhhhh, and its really noticeable yeah?
  36. #35
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    yeah with de cat boost is alot quicker and pulls right to the red line pick up while moving has noticeable difference also.
  37. #36
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    i didntthink there was much benefit in de-catting an S3?
  38. #37
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    There isnt, but there is a lot of benefit in changing the downpipe for a larger one. And its cheaper to decat as well at that point than it is to buy a sports system with cat.
  39. #38
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Quote Originally Posted by Dave_Bayern View Post
    A3 or S3 dave?
    A3 I'd agree...d/pipe is good.
    S3...never seen one yet that makes much by way of power...not on a standard turbo.
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
  40. #39
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    had the same convo with CC when i had my remap.......r.e the downpipe.... cost a fortune for 2-3bhp gain
  41. #40
    SÂŁ's Avatar
    Mar 2008
    Suffolk
    669
    When i was at Jabba a few days ago i spoke to Mike there as they had some stuff on display and he said theres no point with Sports cats,DP's,induction kits etc etc unless you are going for the big turbo otherwise waste of time.
    What they did say is that they have a 450bhp demo S3 which is open to test drives..... But... it was in the body shop so didn't get a look in!! someone crashed into it the previous week. Apparently a cross between a IHI and some other turbo something new on the market and the Kit costs about Ł4500
