Sky InsuranceChris Nott
    Tabs's Avatar
    Mar 2003
    Liverpool
    10
    Koni adjustable shocks
    Getting some FK Konigpsort coilovers fitted to my R32 later this week. The coilovers use Koni Yellow adjustable shocks and I would like some feedback from other owners on what to set the rear shocks to.
    Seeing as the S3 is the closest comparitave vehicle to the R32, I thought I best ask you lot what settings you use!
    And before anyone says it, yes I know the R32 is heavier!
    [img]/ubbthreads/images/graemlins/groovy.gif[/img]
    TIA
    Tabs's Avatar
    Mar 2003
    Liverpool
    10
    Re: Koni adjustable shocks
    Bump [img]/ubbthreads/images/graemlins/crazy.gif[/img]
    RAPS3's Avatar
    Moo Moo Land
    1,065
    If you have a look in the handling forum, I'm sure Ess_Three posted up his settings for the camber, caster, toe in and toe out etc if thats what you mean. As for rebound and compression etc I wouldnt know.
    May 2003
    Ipswich/Glossop
    52
    Although this wasn't my thread, I'd just like to say thanks again Ess_Three. I purchased the Koni adjustable and Eibach springs with a 23 mm front ARB and a 19 mm rear ARB based on your extensive testing. The car goes in next week for fitting so I can now request how I want it setting up as well. Top work fella
    GBH
