EM TuningMonster Motorsport
Results 1 to 16 of 16
    Apr 2008
    Reading
    29
    Headlight adjusters broken - DIY job?
    Hi all,
    I'm new to this forum. I got my Y-reg facelift S3 last Saturday. I've already read through the posts about headlight aim, but I still have a question. The horizontal manual adjust on my headlights seems to be broken inside. The vertical adjust works, but turning the allen key for the horizontal gets me nowhere. I'm very much a DIYer and I was wondering if anybody knows if I stand any chance of looking into this by removing my headlights and possibly looking inside, or whether I'm more likely to screw it up even worse!
    Thanks,
    Steve
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    How many turns of the allen key adjuster have you done? If the previous owner had over adjusted them it wil take alot of winding before you see any movement, i had this previously and was thinking i was gonna have to replace the headlamp. As far as i know you cant buy parts for the internals of the headlamp so if it is broken you will probably be looking at a new headlamp which are circa 480 from the dealer.
    2007 A3 TDI 170 S Line
    Sold - 2002 S3
    rodenal's Avatar
    Oct 2006
    1,982
    It's not difficult to take the headlights apart, but you'd be looking at replacing the little cog anyway, and by the time you found a headlight to butcher to do that you might as well buy a working headlight from ebay, shouldnt break the bank especially for one.Having said that make sure it is broken first as said above
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    Jun 2006
    712
    get a pic up of the broken part. I think I had the same problem recently with the internal locater for the headlamp motors snapping. These can't be bought seperatly but I have found a clip that does the job just as well.
    you dont need to take the light apart if you're careful when replacing it
    Apr 2008
    Reading
    29
    Quote Originally Posted by S3Steve View Post
    Ah, that's useful. I might just try turning for longer. Can anyone tell me which direction to turn to move the beam in which direction? I don't want to be turning one way for ages and then have to go back even further!
    s3ollie's Avatar
    Jan 2007
    749
    Quote Originally Posted by jonS3 View Post
    Hi, i have the same prob. could you tell me where you got a clip that fitted please
    8P S3
    davidhodgkinson's Avatar
    lancashire
    198
    Quote Originally Posted by stevehaskew View Post
    It might help to get an "allen key" socket and attach that to a battery drill.....
    Just remember to keep the torque setting low...
    Was A3 1.8Ts
    Now S3
    Jun 2006
    712
    make sure you dont go too far clockwise otherwise it will unscrew completely
    Apr 2008
    Reading
    29
    I think somebody already found that out... I think it was already completely unscrewed and that's why it doesn't move. I'm guessing I'll need to take bumper off, remove the headlights and open them up to persuade it to go back on the thread
    Jun 2006
    712
    nope, there's a way around it. Take the panel off the back of the headlights and find something to pull on whilst you turn the adjuster anti-clockwise
    it will pull it back on doing this
    ruairi83's Avatar
    Dec 2007
    685
    I have facelift headlights for sale in excellent condition if interested. Msg me...
    Apr 2008
    Reading
    29
    nope, there's a way around it. Take the panel off the back of the headlights and find something to pull on whilst you turn the adjuster anti-clockwise it will pull it back on doing this
    Great. I'll try that. If not, I might be in contact with you ruairi83!
    Thanks guys,
    Steve
    ruairi83's Avatar
    Dec 2007
    685
    No Problem mate. Good luck
    Apr 2008
    Reading
    29
    Well I've got around to having a look. The "open the back, pull on something and then adjust" worked brilliantly for the right hand light, thanks! The left hand one still has a broken adjuster (the gear part on the back has broken off the spindle and disappeared ) but I've bodged it for now. So I'm looking to get hold of one of those bits and get it back together. Thanks all!
    Jun 2006
    712
    no problem!
    ruairi83's Avatar
    Dec 2007
    685
    Just been checking and check this to see if it will help mate.
    http://cgi.ebay.co.uk/AUDI-A3-HEADLA...2em118Q2el1247
