Sky InsuranceVolks Autos
Thread: FMIC core size
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    FMIC core size
    will someone please measure the core size of the forge front mount.
    after that forge kit on ebay went for over Ł600 i'm going to make my own kit.
    but i'm stuck on which core size to use.
    if the core is too big they will be more lag, if the core is too small then cooling will be insufficient.
    the standard intercoolers have a total core size of 5600ccm i'm looking at a core size of 450x230x65 which should work out at 6727ccm.
    I believe this should be big enough and will be easy to hide behind the bumper and no cutting of the bumper bar.
    So far all the parts i have decided on using will total Ł240.
    getting everything to fit is the next part.
    S3 - Gone but not forgotten!
    Jun 2007
    446
    one from mk4 golf is approx 300x500mm, not sure on thickness though
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    is that BT or standard turbo?
    Jun 2007
    446
    its what i ran on my golf with ihi.
    went with the allards fmic kit with big big turbo. that was huge, 500x320x60mm, pipework was only 57mm though.
