Volks AutosChris Nott
Thread: MAF and CTS
    Effect's Avatar
    Apr 2007
    Derbyshire
    469
    MAF and CTS
    Had my car CC'ed yesterday (thanks JBS) and loving it so far.
    However JBS said that i would probably need a MAF within a week.
    Also I have been experiencing some strange temperaure problems which I have read on here are down to the coolant temp sensor.
    So I need to but a MAF and a coolant temp sensor, 2 questions:
    1 - Is there a place to get these cheaper or am I better just going direct to Audi/VW ?
    2 - Do I need a coolant temp sensor or sender ?
    Regards
    James
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    I tried a few MAFs from ebay but they didn't work with my car. I think it had to do with mine being an older model, but I went to VW in the end for a 70 recon item which has been fine. Coolant temp sensor and sender are two terms for the same thing. The sender/sensor itself is two parts combined into one. Half tells the ECU whats what and the other half supplies the gauge on the dash. So you can have a good running car with a dodgy dash display and vice versa.
    Coolant senders are cheap, so just go to VAG for them.
    Hey, did you see my car there yesterday? (Yellow A3 - also in for a map)
    Effect's Avatar
    Apr 2007
    Derbyshire
    469
    Yeh i saw it parked next to a really bright yellow (SEAT I think)
    When mine was done i went outside they had parked it next to yours.
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    It might be worth giving the MAF a clean before you replace it? (only takes 10-15 mins).
    As for the temp sender, make sure you get the latest (green I think) version, again you can change this yourseslf quite easily (just make sure the engine is cold so you don't lose much coolant)
    There are how to guides here somewhere, if you can't find them drop me a pm as i've got them saved on my pc.
    Mike
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Quote Originally Posted by Effect View Post
    Cool. Can't miss mine, its covered in dirt at the mo.
