EM TuningChris Nott
Results 1 to 22 of 22
    S3 Dave's Avatar
    Now running on Heavy Oil
    Jul 2007
    Middle England
    432
    Air con code for coolant temp??
    When using the air con codes. What is the number for coolant temp???
    I think its 51 can anyone confirm????
    "Never in the field of human conflict was so much owed by so many to so few"
    Churchill August 20th 1940
    NoggyDS3's Avatar
    Oct 2007
    Scotland
    193
    Its 49 on mine mate.
    2001 Facelift S3, Custom Code Phase 1, Forge 007p
    Jun 2006
    712
    I think it's 51 actually, 49 just goes up to 90 slowly and stays there. or it could the other way round, you'll know by looking tho
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    what are you talking about with the air con????
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    NoggyDS3's Avatar
    Oct 2007
    Scotland
    193
    Sure it's 49 on mine as i used it very recently as i was having probs with temp/thermostat. Maybe it can vary? Like you say, best bet is to check and see!
    Animal - if you press the 'recirc' and 'up' buttons together on the climate control unit it should show '1c'
    Then press the temp '+' or '-' buttons to choose a code for checking various values (in this case either 49c or 51c) Then press the 'recirc' button again and it should show the value for the for the coolant temp.
    There's a few things u can see, RPM, speed etc.
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    brilliant, didnt know about that...... i take it these values remove the usual climate reading? also how do you revert back to the climate
    NoggyDS3's Avatar
    Oct 2007
    Scotland
    193
    yea - it removes the climate figure. You just press recirc or auto to put it back to normal.
    The fan speed buttons work as normal in either mode though!
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    so if the coolant temp is 49....then does that mean i have to click 49 times?????
    NoggyDS3's Avatar
    Oct 2007
    Scotland
    193
    Pretty much... unless you go backwards (can't remember what the highest code number is...) Either way, 49/51 is as near as dammit in the middle!!!
    Or, you can just press and hold to save clicking! only takes about 10 secs.
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    okies....so you can view, speed, rpm, temp..... whats the other 46 options?
    NoggyDS3's Avatar
    Oct 2007
    Scotland
    193
    There's more than 49! Not sure what all of them do but there's temps from various places all round the car: interior/exterior also loads of potentiometer values for god knows what! Think it's basically everything the CC needs to know to operate efficiently.
    But certain ones are just good for a cheap way of diagnosing some wee problems!!!
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    ahhhhhhhhh cheers for that noggy...will have a go on my way to work in the morn
    NoggyDS3's Avatar
    Oct 2007
    Scotland
    193
    No bother, think 27c is RPM for interest if you're playing, and sure 49c is ECT on mine.
    Will check tommorrow and post back for Dave.
    grathies's Avatar
    More Points Than Portsmouth FC
    Dec 2004
    Portsmouth, Hampshire
    1,355
    Anyone got a definitive list of what positions what?
    grathies's Avatar
    Dec 2004
    1,355
    Press and hold the recirculation button. Then press the manual flow control up arrow. You should see a 1c. Press the temperature up ("+") or down ("-") buttons to select a code number. Then press the recirculation button again. The value should display. Press the temperature up or down button again to display another code.
    NOTE: Air Flow Motor (V 71) and Potentiometer (G 113) are not installed in USA/Canada vehicles. Disregard values displayed for these components.
    Code Displayed Value
    1 System malfunction - displayed as a Diagnostic Trouble Code (DTC), see chart below
    2 Digital value of Interior Temperature Sensor, in Headliner (G 86)
    3 Digital value of Interior Temperature Sensor, in Instrument Panel (G 56)
    4 Digital value of Fresh Air Intake Duct Temperature Sensor (G 89)
    5 Digital value of Outside Air (Ambient) Temperature Sensor (G 17), front
    6 Digital value of Outside Air (Ambient) Temperature Sensor
    7 Digital value of Ambient Temperature Sensor At Fresh Air Blower (G 109)
    8 Digital value of Temperature Regulator Flap Motor Potentiometer (G 92)
    9 Delta value of Temperature Regulator Flap
    10 Non-corrected specified value of Temperature Regulator Flap
    11 Digital value of Central Flap Motor Potentiometer (G 112)
    12 Specified value of Central Flap
    13 Digital value of Footwell/Defroster Flap Motor Potentiometer (G 114)
    14 Specified value of Footwell/Defroster Flap
    15 Digital value of Air Flow Flap Motor Potentiometer (G 113)
    16 Specified value of Air Flow Flap
    17 Vehicle Speed (km/h)
    18 Actual Air Blower voltage (Volts)
    19 Specified Fresh Air Blower voltage (Volts)
    20 A/C Compressor (A/C Clutch) voltage (Volts)
    21 Number of low voltage occurrences, non-transient
    22 Cycle condition of A/C Refrigerant High Pressure Switch (F 118)
    23 Cyclings of the A/C Refrigerant High Pressure Switch (F 118)
    24 Cyclings of the switches, absolute non-fluctuating
    25 Analog/Digital value, Kick-Down Switch
    26 Analog/Digital value, Engine Coolant Temperature (ECT) Warning Light
    27 Coding value
    28 Engine Speed (RPM)
    29 A/C Compressor speed in rpm (Equals Engine Speed x 1.28)
    30 Software version
    31 Display check (all segments of A/C Control Head display light up)
    32 Potentiometer malfunction counter, Temperature Regulator Flap
    33 Potentiometer malfunction counter, Central Flap
    34 Potentiometer malfunction counter, Footwell/Defroster Flap
    35 Potentiometer malfunction counter, Air Flow Map
    36 Feedback value, cold end-stop, Temperature Regulator Flap Motor Potentiometer (G 92)
    37 Feedback value, hot end-stop, Temperature Regulator Flap Motor Potentiometer (G 92), max. stop
    38 Feedback value, cold end-stop, Central Flap Motor Potentiometer (G 112)
    39 Feedback value, hot end-stop, Central Flap Motor Potentiometer (G 112)
    40 Feedback value, cold end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
    41 Feedback value, hot end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
    42 Feedback value, cold end-stop, Air Flow Map Motor Potentiometer (G 113)
    43 Feedback value, hot end-stop, Air Flow Map Motor Potentiometer (G 113)
    44 Vehicle operation cycle counter
    45 Calculated interior temperature (internal software, in digits)
    46 Outside (ambient) temperature, filtered, for regulation (internal software)
    47 Outside (ambient) temperature, unfiltered, (internal software, in deg C)
    48 Outside (ambient) temperature, unfiltered, (in digits)
    49 Malfunction counter for speedometer (vehicle speed) signal
    50 Standing time (in minutes)
    51 Engine Coolant Temperature (ECT) in deg C
    52 Graphics channel 1 - A/C compressor switch-off conditions are identified by illuminated segments of the “88.8” display. See chart below.
    53 Graphics channel 2 - Climate system electrical outputs are identified by illuminated segments of the “88.8” display. See chart below.
    54 Control characteristics
    55 Outside (ambient) temperature, in deg C or deg F depending on setting on A/C control head
    56 Temperature in deg C, from Interior Temperature Sensor, in Headliner (G 86)
    57 Temperature in deg C, from Interior Temperature Sensor, in Instrument Panel (G 56)
    58 Temperature in deg C, from Fresh Air Intake Duct Temperature Sensor (G 89)
    59 Temperature in deg C, from Outside Air (Ambient) Temperature Sensor (G 17), front
    60 Temperature in deg C, from Ambient Temperature Sensor At Fresh Air Blower (G 109)
    61 Software version (latest)
    Found from a previous post by Kevint
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    so no speed in MPH.........
    grathies's Avatar
    Dec 2004
    1,355
    No, thats why you have a speedo infront of you
    Not gonna me much different accuracy wise anyway dude, their reading from the same sensor
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    just curious lol
    grathies's Avatar
    Dec 2004
    1,355
    Quote Originally Posted by 1animal1 View Post
    just curious lol
    Not another curious one!
    Go join Nick and Ibzzzzzzz in their Curious thread dude
    NoggyDS3's Avatar
    Oct 2007
    Scotland
    193
    Weird... Just checked on my car and my ECT is 49 and my RPM is 27 - Obvioulsy not gone through all of them but mine is def different to that list Grathies!?!?!
    grathies's Avatar
    Dec 2004
    1,355
    Quote Originally Posted by NoggyDS3 View Post
    Quote Originally Posted by grathies View Post
    NoggyDS3's Avatar
    Oct 2007
    Scotland
    193
    Mine must be special...!
