Chris NottAH Fabrications
    Crazypete00's Avatar
    Oct 2007
    266
    Battery problems
    Hi all,
    im having a few problems with my car. i have an Audi S3 and my battery keeps going flat.
    go to the car in the morning, put the booster on it, go to work about 15-20 min drive, 1 hour later battery dead.
    i checked it with a volt meter the alternator is charging it fine (14 volts) and when the car isnt running it stays at around 12.3 to 12.1.
    i plugged vagcom into it, a few errors but nothing related.
    any ideas? could it be the waterpump that runs after the engine is off?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Do a current check on the car.
    Remove the battery positive lead and then add a multimeter set to read amps between the positive lead and the battery.
    Then turn everything off on the car and see if you are getting a reading. If you do, start pulling fuses until the ammeter drops to zero. This should at least indicate the circuit causing the problem.
    NoggyDS3's Avatar
    Oct 2007
    Scotland
    193
    I had similar problems on mine when my seat switch broke!
    2001 Facelift S3, Custom Code Phase 1, Forge 007p
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    you can`t really test a car betery with a avo you need to put a hefty load on it. A Battery spot can do this for you but it sounds like you just need a new battery. I got a Bosch silver one for about 60 quid, I think varta do a nice one as well iirc.
    red to red black to black blue to bits
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,592
    Sounds like a dead battery to me from personal experience, what year is your S3?
    Oct 2007
    266
    thanks guys, i think it may be a dead battery, charged it last night, put it on the car - DEAD. so now need a new one.
    car is a facelift 2001
