    Essflee's Avatar
    Mar 2008
    1,995
    Help !! vag com codes
    Just bought a Vag code reader, and need help with the codes
    Any idea's...
    17963 Charge pressure maximum exceeded
    16712 Knock sensor 1
    If not, where can i get these identified ?
    Thanks...
    h100vw's Avatar
    Aug 2006
    Down South, next stop Antarctica
    215
    ross-tech.com have big list of the DTC codes.
    Gavin
    Essflee's Avatar
    Mar 2008
    1,995
    Cheers gavin... just found the codes !! i'm going to get the N75 valve replaced, hopefully cure the problem. Failing that, if my car is boosting to much, how the hell am i supposed to sort that out, bar getting the map taken off... which really isn't an option !!
    stapo69's Avatar
    All hail the mighty quattro!
    Mar 2007
    966
    I had a similar charge preesure code when I popped one of my intercooler hoses off, so maybe a boost leak somewhere?
    MRC-Powerflex-Hotchkis-Porsche-Compomtive-Vredestein-034-JHM-Apikol-EBC-FK-Labree-Vibrant-Recaro
