EM TuningChris Nott
Thread: Help needed??
    Stepho's Avatar
    Feb 2004
    Strathclyde
    443
    Help needed??
    Hi there, my father-in-law has a 52 plate A3 1.6, and is having problems with the indicators not flashing. He thought it was down to a relay problem, both he and I have had a scout around and can't find any sign of a relay. Has anyone ever had this issue, or can someone advise on the problem.
    Thanks in advance
    jamieface's Avatar
    the only S3 in the villiage
    Oct 2007
    Cheltenhamshire
    198
    hey there i had the same problem with my S3. the relay unit is actually part of the hazard light switch if you go to audi with your engine code they will give you a whole new unit its very easy to replace takes only 5 mins.
    hope this helps
    Stepho's Avatar
    Feb 2004
    Strathclyde
    443
    Is it easy to remove the hazard warning switch? Also any idea of cost? I had an S3 a few years back but to be honest can't even remember where the switch is.
    jamieface's Avatar
    Oct 2007
    Cheltenhamshire
    198
    its dead easy to remove. its the big red triangle button in the middle of the dash ! all you ned to do is carefully prize away the dash trim but be careful because it is fragile then slide out the hazard light button unplug and take it to audi and they will give you a nice shiny new one for about 20 quid
    Stepho's Avatar
    Feb 2004
    Strathclyde
    443
    Thanks Jamie
    jamieface's Avatar
    Oct 2007
    Cheltenhamshire
    198
    no problems mate. Everyones here to help !!!
