JMB RetrofitsEM Tuning
Results 1 to 18 of 18
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Anyone tried deleting the PCV check valve??
    I was just giving my car a once over be for a remap on Monday when I found a boost leak in the PCV system under the inlet manifold.
    Pic of area (pipes removed)
    No real issue I though so I bought some new pipes and a new non-return valve that sits in the tee piece as the old one was leaking. However, the new non-return or check valve also does not hold pressure in a simulated boost situation (my gob blowing into it ). Also checked with a mates valve too, same result.
    This is a constant boost leak in my opinion which allows boost into the PCV and a badly designed weak valve.
    So now I'm thinking of removing this valve altogether and only allowing crankcase gasses to vent into the TIP. I can't see the point of the small pipe to the inlet anyway. Anyone else tried removing the valve?
    Thanks.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,377
    Let us know how you get on Kev, I was thinking of installing a catch tank in my PCV system to try and limit the insane amounts of oil that is being vented into my TIP and slowly filling up my intercooler!
    I wasn't aware of the system in your pics under the inlet, very interested to see if mines a problem at all. My car is still only holding 10psi to the redline. I'm going to try bypassing the N75 tonight to see what my wastegate is set at, and if thats not the issue, I'll check out those PCV pipes.
    Feb 2004
    2,036
    is the pcv the little lack placky valve in the rubber hose from the maf to the tip, sort of positioned near to the dv?
    Bellic's Avatar
    Dec 2006
    253
    how do you check what your wastegate is set at , i have a forge on mine but need to get it set right what should it be reading on gauge is it 0.4?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    This is indeed the pressure control valve for the crankcase breather system. If you look at the second pic, it connects to the pipe end on the far left.
    I've emailed JBS to get their opinion. I think I'll block the thin pipe to the inlet tomorrow and see how the car drives.
    Feb 2004
    2,036
    There is an interesting thread on ukmkivs about boost leaks from the pcv and one guys thinks is the rocker cover on his agu.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Do you have a link to the thread?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Had the breather apart again today. The new valve is faulty I'm sure, but the old valve holds pressure when it has a film of oil within it. I wonder if this intentional? Just been out for a drive and the car is real quick. I was only boosting to approx 15psi after the turbo swap. Now it will boost past 20psi. Couldn't really boot it as fueling isn't right.
    Roll the remap on Monday!
    If it starts to leak in future, I've got a spare check valve from a brake servo pipe that I'll add.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    Monster bump:
    Kev, you're possibly my favourite person right now.....
    I've just dug up this thread and had a look at what you found, then gone and compared it to my car outside, to find the hose under my inlet manifold is FAR worse than yours in the above pics.
    I'm REALLY hoping this could go some way to explaining my boost problems now!
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,234
    Hope you get it sorted now mate.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    I told you these cars are a nightmare! Hope this sorts you out and saves you buying a new turbo!
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    hmmm, just trying to see the downside to this mod IF you have a catch tank fitted? essentially the catch tank is a direct replacement for this valve surely.....
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,234
    All the sc.net guys get rid of the mushroom valve and just replace with a 90' elbow.
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    yup and plumb in a catch tank like yours yeah?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,234
    Yup, by the way mine does work tim
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    yea, the SCN guys just delete the vacuum feed altogether, and let it vent to the catch tank before anything returns to the TIP. in reality, if the engine has enough breathers, the PCV system shouldn't be needed, and it should be more than OK venting naturally.
    I'm not going to delete the valve on mine, as there's no need. I've just ordered a new check valve and hose from Audi, and I'm going to fit an aftermarket check valve inline before the PCV valve too, just to be 100% sure it's leak free
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    i thought the idea was for it to fully breath back into the TIP.... whereas IIRC other 1.8T's have breather filters..... wouldnt this reduce pressure and potentially be a tiny leak/weak point of the system...as opposed to fully breathing via a closed catch tank back into the TIP
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    well, the whole idea of the pcv valve and the inlet connection is to use vacuum from the inlet to draw the gasses out of the crank case. as my vacuum pipe is split, the system hasn't been recieving any vacuum in a while, so i guess it can't hurt to just plug up the hole in the inlet for now, and see if it improves performance!
    I'#ll be picking up the new hose from audi tonight though, along with a new check valve to be safe.
