Chris NottSky Insurance
Results 1 to 12 of 12
    mattyboy199's Avatar
    Nov 2005
    UK
    1,679
    Oil change ? Castrol professional ?
    After my visit to Jabba back in October time i had noticed that they used Castrol professional & from what i understand is 5W-30. After a quick search i have concluded that Castrol Magnatec 5W-30 is infact Castrol professional or the same as. Anyway i m planning an oil change so though i would run it past you guys.
    Can anyone confirm the above ?
    Matt
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    I would use castrol edge,its fully synthetic.
    Nov 2005
    UK
    1,679
    Can someone answer my question (not being rude) Also, how many litres does the S3 engine take ? is it worth using an engine flush ?
    wanted for 8L S3:
    Milltek system
    Nov 2005
    UK
    1,679
    Bump
    wanted for 8L S3:
    Milltek system
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    S3 engine will take a little under 5 litres with a filter change. I usually pour in 4.5l and then top up if necessary.
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Did you find what you was looking for?
    I wouldnt put a mineral oil in an S3?
    Nov 2005
    UK
    1,679
    Yes i did, i contacted Jabba & asked their advice.
    Castrol Edge is suitable although they recommended Casrtol SLX 4 which i cant find anywhere.
    They also said they have moved over to Mobil one ESP formula which i ll probably use as they sell top ups at the Esso stations.
    A bit confused why these oils only come in 4 litre tubs when for instance the S3 requires 4.5litres (i only checked Halfords though).
    wanted for 8L S3:
    Milltek system
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Quote Originally Posted by mattyboy199 View Post
    I know its a right pain in 4 litre bottles.
    Didnt castrol slx just change name to castrol edge?
    I have just started using silkolene pro s 10w/50,excellent oil and comes in 5 litres.
    Looks weird though,its red.
    Nov 2005
    UK
    1,679
    hmmm i would be careful you can only use certain oils so just check its compatible.
    wanted for 8L S3:
    Milltek system
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Its in my GT-four.
    Oilman recommended this stuff so must be ok.
    Nov 2005
    UK
    1,679
    I would seriously check weather that oil is sufficient. It might be ok in your GT Four which is pretty old by now. There are certain requirements for the newer engine running semi sythentic may not be a good idea, this is just what i ve been told & i dont know if that oil is semi. check it out !
    wanted for 8L S3:
    Milltek system
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Ester fully synthetic,top quality oil.I wouldnt put semi in a turbocharged car.
