AH FabricationsVolks Autos
Results 1 to 9 of 9
    sprout99's Avatar
    Jun 2006
    North East - Dodge city
    367
    Lower grille removal
    Can somebody advise me ....i've tried searching but no luck.
    How do the lower grille come off? I know if you were going to be towed you take off one to put toe eye in. But thats the wrong side.
    I want to get at the front of the intercooler
    any pointers?
    Ian
    2004 AUDI A3 S-LINE DSG TDi
    MAURITIUS BLUE
    2005 BMW 120d M Sport 163+
    BLACK SAPPHIRE
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    IIRC, you need to remove the bumper first, which is very straight forward. Remove the plastic clips uner the bonnet at the front, then 2 srcew under the bumper. Remove some screws inside the wheel arches and pull the sides outwards. Then you can pull the bumper out the front.
    If you have headlight washers there is a clip under the bumper to disconnect them, but you don't have to. Reast the bumper on an old blanket.
    Then you can get to everything.
    sprout99's Avatar
    Jun 2006
    367
    bumper off ?!
    oh bu66er
    MAURITIUS BLUE
    BLACK SAPPHIRE
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    Quote Originally Posted by sprout99 View Post
    bumper off ?!
    oh bu66er
    very easy job
    jesters3's Avatar
    The Shire's
    1,516
    Quote Originally Posted by abdus View Post
    very easy job
    Agreed, very straightforward to do even for one person. When opening the bonnet there are 4 black thin round plastic holders that you have to push through to release the top of the bumper. I used coat hanger to push them through (the wire was the right thickness to push in the holes)and then a pair of pliers to catch them on the other side.
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    sprout99's Avatar
    Jun 2006
    367
    managed to un clip it last night without bumper removal - very easy
    and obviously meant to since tow eye is there
    loads of crud blocking intercooler fins - all clean now
    MAURITIUS BLUE
    BLACK SAPPHIRE
    scott_johnson's Avatar
    Audiless
    Bingley
    875
    Is that the middle lower grille or the right hand side (fog surround)
    sprout99's Avatar
    Jun 2006
    367
    drivers side - side grille where intercooler is on tdi
    MAURITIUS BLUE
    BLACK SAPPHIRE
    Audiless
    Bingley
    875
    ahh i see. if its the same as the s3, you put your fingers in the slats and sqeeze the top and bottom and pull towards you. Still need to get the middle 1 off to get to my fmic!!
