Volks AutosJMB Retrofits
Results 1 to 15 of 15
Thread: clutch tips
    bazza s3's Avatar
    Oct 2007
    52
    clutch tips
    hi people im going to change my clutch at the weekend. just wondering has any one got any tips or is there anything to watch out for thanks
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    Replace the slave cylinder at the same time...
    Black S3
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Remove the subframe if you have time. Makes the job easier as it gives you more space to wiggle the box out. Down side is you'll need to get your wheel alignment checked.
    Try not to swear at the air con pipe too much. Have fun.
    Bellic's Avatar
    Dec 2006
    253
    doesnt the subframe need to come out anyway on the quattros?
    bazza s3's Avatar
    Oct 2007
    52
    thanks people not realy looking forward to doing it doesent look fun! ill let u know how i get on tomorrow.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Quote Originally Posted by nikquatty View Post
    Not sure, you could be right there.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    I found it to be silly things like the afore mentioned aircon pipe hooking up on things and preventing the flywheel from turning when undoing and tightening clutch bolts.
    Getting the box on again is fun. Lift, wiggle, (doh, me arms are aching)....relax. Then repeat until it slides on. You'll probably need to lower the gearbox end of the engine tilting it down to aid removal.
    You got an engine support to go on the top of the wings?
    bazza s3's Avatar
    Oct 2007
    52
    yea got engine support doing it at work. i usually work on trucks everything is easy to get to on them. doesent look like there is a lot of room on the s3 think my nuckles are gna suffer oh well.
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    good luck bazza,i also work on trucks mate i work for Daf in Reading where do you work
    A4 TDI S-LINE
    bazza s3's Avatar
    Oct 2007
    52
    i work for a place calld facelift mainly work on volvos.
    well the gearbox is out havent put it back in today becaus i ran out of time didnt start it till 12 the aircon pipes are a pain in the ass no matter where u put em there in the way gna put it all back tomorrow cant wate (not)
    Bellic's Avatar
    Dec 2006
    253
    did you have to take the subframe off?
    bazza s3's Avatar
    Oct 2007
    52
    yea you havent got a chance with it on there.
    bazza s3's Avatar
    Oct 2007
    52
    does any one know if there is any special way of bleeding the clutch??
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    Same way as bleeding a set of brakes, mine bled up within a few minutes.
    Black S3
