- Joined
- Feb 16, 2004
- Messages
- 1,009
- Reaction score
- 6
- Points
- 38
- Location
- North East
- Website
- www.audi-sport.net
...with these fault codes?
Address 01 -------------------------------------------------------
Controller: 06A 906 018 AQ
Component: 1.8L R4/5VT MOTR HS D03
Coding: 04000
Shop #: WSC 06313
2 Faults Found:
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-10 - - - Intermittent
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
Readiness: N/A
My main concern at the moment is the Throttle Valve Controller. Could this be directly linked to the lambda probe malfunction? Any simple remedies for this?
I have cleared the codes, and will check them again (hopefully tomorrow) after a couple of journey's.
Recently my car has been sweating a small amount of coolant - not sure if that would suggest any further signs? I'm booked in to the garage next week to get this looked at, and I'm going to have the lambda probe investigated (cleaned), and see if that settles my intermittent lambda code - if not I think a replacement will be best. It does seem to be very sporadic.
Thanks in advance!
Rob :icon_thumright:
Coding: 04000
Shop #: WSC 06313
2 Faults Found:
Readiness: N/A
Thanks in advance!
