The cooler is the same size as mine height and width, but it looks thinner in depth. I had to cut massive chunks out of my crash bar to accomodate the FMIC. Good news for yours that you didnt have to! I heard that the pro alloy ones need the radiator tilting back, is that right? Or do you not have Aircon?
I like where the pipes go in/out, means the whole thing can be hidden.
I wouldnt worry about cooling too much, if the stock setup provides adequate cooling to the aircon radiator and engine radiator, then it'll be enough for the FMIC too, especially as its mounted up front.
On the subject of the pipes, I assume the drivers side is straight out the throttle body into that bendy pipe, but where does the passenger side pipe route? Any pics of the pipe routing?
Above you have written its the opposite way, but if its an A3, the throttle body is on the left hand side.
Pics?
