Throttle Body Problem
Mickeybhoy67
glasgow
Hi All
I have an Audi A3 98 which has a problem with its throttle body. I have done a diagnostic which brought up fault code 00282 - throttle position actuator.
The car basically doesn't start properly from cold. I have to keep my foot on the accelerator until the idle catches.
Does anyone know anyone who would be able to help me in the Glasgow Area???????/
Cheers for the help!!!!!
Sounds similar to my problem except mine doesn't throw up any fault codes. Voorhees had same issue until he either replaced or cleaned the throttle body. I'm sure he'll be along soon.
is cleaning the throttle body a good thing to do regularly anyways? if so how easy is it to remove
Just done mine, very easy, and well worth the effort. Mine is a 2000 W, so needed a clean. Do a search instructions/pics on here somewhere
my brother had a similar problem on his old seat ibiza a few years back, if i remember it cost him about £35-40 to get the throttle body cleaned and it was fine and dandy after that.
dom
clean and realing I think is the answer. think there is a FAQ on this somewhere, maybe on VW vortex...
Good un...worth getting a new Gasket too. They are 1.95 from Audi.
ooooh thats a job im defo gonna attempt on the weekend....can you align the throttle body with a non purchased vagcom?
That's a great link thanks Rob. I'll give mine a go at the weekend.
It's with Audi to get a problem with the intake camshaft sensor sorted on Friday, I'll do the throttle body on Saturday, then it gets a remap on Monday. Then on Tuesday it's in to get the roof rails resprayed, followed shortly by a full paint correction and detailing. Busy week for my motor! :)
No worries mate
Sounds like your car is getting lots of TLC :w00t:
Quick question to people - does anyone know if bake cleaner would be ok to use to clean the TB? Or does it HAVE to be carb cleaner? I think the two are pretty similar. :shrug:
Any ideas?
Rob
No worries mate
She deserves it :) I've only had her a couple of weeks and she's done 108k miles so I'm just trying to bring her back to her former glory :) Half the work is warranty stuff anyway luckily.
Just to add, if your car has a throttle cable you don't have to re-align with vag-com. All you need to do is turn the ignition on without starting. Don't touch the throttle pedal and wait for the throttle body to stop buzzing after 20-30 secs or so.
well I'm literally all ready to go with cleaning my TB, however - somethign I didn't compensate for: the throttle cable is attached to mine! does anyone have any tips on how to tackle this? I don't fancy disconnecting all that!
I'd really like to get this done tonight, so if anyone can help that would be super!
Rob
***edit***
here's a couple of pics:
in this one here, you can see the end of the cable that has a little stopper on the end - do I just need to losen this off, to free it up? then pull the cable back out and attach it when finished? might be obvious - but I don't want to f**k it up!
erm...was gonna whip mine off this weekend.......... one...i havent got a torque wrench (is this majorly important)....two..... i only have the sample version of vagcom....can i realign it with this (i dont have a wire throttlebody)
You dont need a torque wrench just tight it quite hard with the rachet. To loosen the cable just manually push the mechanism as if was opening the throttle, this should slacken it helping you to take it off.
so I do need to remove the cable from it's little 'housing'?
will I be able to pull it back over easy as well? (I have thoughts of it zooming off like a tape measure! lol)
thanks
Don't go mad on the tightness. You only really need to nip them up. Hard to explain in words what feels like. But it isn't loads. To are screwing into aluminium remember.
About the cable, pull the rubber part of the cable off the support on the inlet. Then you will have enough slack to push the cable out of the throttle cam and the end out of the holder.
Thanks Kev.
In the end I just went for it. I removed the cable with ease. Took me ages to remove the bolts! At first it didn't look too dirty, though when I got to the other side it was caked in gunk! Spent a good time cleaning it all back up to new and shiny. After reading your post I am worried that I may have tightened up the bolts too tight in the end though - I don't have a torque wrench (my tools are pretty limited, having to add extensions on here and there! lol). Hopefully I'll be ok :uhm:
Rob :)
any answer on the vagcom question??? can the unpurchased vagcom recalibrate my Throttle body
ok, weird one....had the body off today..... not much muck there at all apart from a small bit of oily residue sat at the bottom of the butterfly.....assume it has been done at some point.....or can it just be this clean???
at first I didn't think mine was too bad.
Then I got to the other side.... :scared2:
though after a bit of cleaning, got it up to this:
time wasn't really on my side and the rain was well on it's way. chuffed I managed it though :)
Rob
woah!!! that looks nasty lol..... your clean side was the dirtiest on mine with a small black patch on the cloth i used....that was it? dont think JBS would have touched it when they remapped so can only assume the previous owner did
Just did mine today at is was grubby as feck! First time i've done it. Not really noticed any difference yet but only had it out for a 30 min drive so hopefully i'll notice a wee difference in mpg/response once the ECU has relearned. Even if i dont, at least i know it's clean now!!!
12
11
I
968
imported_VaulterTim
I
