Sky InsuranceEM Tuning
Results 1 to 13 of 13
    Forever going forward!
    Dec 2007
    Bridgend, South Wales.
    20
    1.8T Overheating?????
    Hey guys,
    I know this has been covered before but cant find a difinitive answer to my problem.
    My car has started overheating. I replaced thermostat and temp sensor about 8 weeks ago. Car gets to operating temp as normal then creeps up. Hose from the thermostat housing to bottom of radiator stays cold throughout while other hoses get hot.
    Car is a 2000 1.8T Aum with just over 80k.
    Could this be a faulty thermostat? Or something worse like the water pump?
    Is there any test I can perform to check the if the water pump is u/s?
    Many Thanks, Graham.
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    have you checked coolant level?
    what temperature does it sit?
    Jan 2007
    Hertfordshire
    520
    Looking at it logically it would seem as though the waterpump is knackered. If one side of the cooling system is cold and the other piping hot its not pumping the water to dissipate the heat?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Start the engine and look at the coolant expansion bottle. There should be a jet of coolant squirting in from the small top hose. Get a friend to rev the engine up to 2000rpm. If you see no jet, then the pump is most likely fugged.
    Dec 2007
    20
    Thanks guys,
    Quote Originally Posted by HTC View Post
    Should I do this at operating temp or will it be the same from cold?
    Thanks Again!
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    It will be the same at any temp.
    Dec 2007
    20
    Ok cheers,
    I have just gone out and at operating temp with expantion cap off I increaded the revs to between 2 and 3k and there IS coolant returning to the tank via the small top hose.
    Would this mean the water pump is ok as there is coolant being pumped around the system?
    Could it be a that the thermostat is stuck closed?
    EDIT: ITS THE AGU ENGINE NOT AUM.....
    Thanks Again, Graham.
    Sep 2003
    medway,kent uk
    103
    if it of any help mine was the water pump even though it was pumping water through the return into the expantion tank,
    stevie
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    when was the cambelt and water pump done?
    Dec 2007
    20
    Ok Cheers,
    Gonna remove the thermostat tomorrow and use the old 'cup of hot water' trick to see if it opens.
    If not ill replace it, if it does ill have to put the car in and get it checked.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Does it overheat in slow traffic or when you are driving at higher revs?
    Maybe the pump impellor is slipping on its shaft?
    Whilst you have the thermostat out, you can shine a torch in a check the condition of the pump.
    Maybe you have been unlucky and the new thermostat is faulty. Happens from time to time.
    May 2007
    323
    just a thought....Is the fan coming on ? i had a similar problem on my corrado which turned out to be knackered bearings on the fan which caused it to intermittently switch off when the engine was hot.
    Audi S3 Ming Blue
    BMW 2.0td Compact Flamenco Red
    Mk3 Golf Gti Indian Red (gone but not forgotten........ the most reliable car ive ever owned...)
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Good call. Check the fan.
