JMB RetrofitsChris Nott
    Feb 2008
    6
    Suspension problems
    Went to change my standard suspension set up yesterday and replace it with a weitec GT 20/15 kit. When I got to the section that involves removing the strut from the wheel bearing housing, I found that there was not enough room to play with to get the strut out. What can be done to over come this.
    Secondly, I aborted the install and went ot put everthing back together and now the link arm from the ARB to the shock does nto line up for me to reconnect it.
    Help needed please. To top it of it is now snowing this morning and I need the car back on the road for tomorrow.
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    What guide were you using? This is the best one: http://www.nclh.org/car/coilover_howto/
    (the 4-mo setup you have on the S3 isnt significantly different that the guide doesnt make sense)
    You need a hub spreader tool. I made my own by grinding down a 8mm allen key.
    <Insert meaningless geeky specs here>
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    The stut body it an interferance fit into the wheel bearing housing. Round the back of the wheel bearing housing is a long slot running vertically. To release the shock you have to prise the slot apart temporarily. There is a special tool for this, but sturdy ended screw driver or any oval shaped item can be used. You only need to prise is enough to release the pinch. Also there is a bolt at the back of the shock locating it.
    As for the arb connection, if you jack up both front wheels together to should find it possible to reattach the fixing. If you were trying with only one wheel up then the arb will be following the position of the other wheel and it won't line up.
