Monster MotorsportChris Nott
    Jan 2007
    S3 BOSE Head Unit Frozen
    Hi
    Has anyone else had there BOSE radio Freeze on them when the buttons do not work and it can not be switched on or off.
    It has the red back light still on but no words appear on the screen and nothing works.
    How can this be resolved - it has been like it for a good few days and no change- the battery seems to be ok as it starts ok!!
    Should I disconnect the battery - or will this mess up other things?
    Any ideas, is there a reset switch?
    Jun 2003
    World of my own
    9,813
    You'll need to disconnect the battery, or pull the HU and unplug the black power plug, also check fuse on the rear of the HU and at the fusebox. Depending on the year of the car you may need to reinput the security code, so ensure you have the tear off card with the 4 digit number on it on the inside cover of the radio manual.
    Alex Turner
    davidhodgkinson's Avatar
    lancashire
    198
    I had this and i removed and replaced the fuse in the fusebox by the door.
    That cured mine
    Was A3 1.8Ts
    Now S3
