Sky InsuranceJMB Retrofits
Thread: Radiator Leak!
    Aug 2007
    Radiator Leak!
    Hi there.
    I've recently started learning to do things for my Audi A3 1.9tdi (V-Reg, 1999) so I'm no expert. I had a little problem with my car, and was told by a garage that my radiator was causing it (car hitting 90 degreese VERY quickly & loss of coolant over a period of a few weeks). I topped up the coolant a few times over the last month or two, but it keeps happening - the warning light comes on on the dashboard display, and the expansion tank is EMPTY! I decided to do what the garage said - and jeez, he was right - the radiator in my car was battered, and it had dried pink ooze at the bottom of it - clearly been leaking. Anyway, all new radiator has been fitted. Since I've done this though, I spotted a leak when I was flushing the system with water - the lower radiator hose seemed to be drippping, ever so slowly. I have since replaced this, and it seemed to make the problem go away whilst i ran the engine to test for more leaks, but it appears now that something else is leaking - the ECT sensor which is just above that hose, connected to the radiator. Like I said, I'm no expert, but I don't understand how something like that could leak - if so, is it as simple as replacing the ECT sensor, and spotting any more leaks? Should I go main dealer or GSF? And, I've read somewhere about a new "green" ECT that is supposedly better than the standard black one. Any help is greatly appreciated. Thanks.
    Taj.
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    egg yolk lol.......no dont
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    Dec 2006
    190
    I take it you mean the fan switch screwed into the rad? could be that its not screwed in properly, try tightening it up a bit. if you want to replace it, anywhere will do it, not just gsf or main dealer. try any motor factor.
    davidhodgkinson's Avatar
    lancashire
    198
    I think you mean the temp sender.
    Have a look on VAGPARTS for the sensor and replace the rubber o-ring seal and the locking clip
    Was A3 1.8Ts
    Now S3
