EM TuningJMB Retrofits
Results 1 to 26 of 26
Thread: Haldex problem
    edward_harris's Avatar
    s3 gone now a shiney red evo 6
    Jan 2007
    berkshire, Reading
    1,062
    Haldex problem
    Hey guys
    changed my haldex controller the weekend for a standard one, ever since then its only been front wheel drive. A little oil came out but not alot really. So i put the uprated one back on, and still its front wheel drive. Checked fuse number 31 looks fine. What else can it be? Also how do you check the haldex oil level and change it?
    Xbox online id - supaed133
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    eeerrrrrmmmmmm...... couldnt you ask a simple question
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    Jan 2007
    berkshire, Reading
    1,062
    Meaning its only front wheel drive 4wd dosent engage. i just get loads of wheel spin
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,592
    I recommend you do a vagcom check on your car ed, sounds like a loose connection or something, if it was working before.
    Jan 2007
    berkshire, Reading
    1,062
    anyone with VAGCOM in the area?!
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    I have it (A4 Twyford/Wargrave) and Nick Evelry has it (Jct 11)
    <Insert meaningless geeky specs here>
    Longman's Avatar
    vassdignostics.co.uk
    Jul 2007
    Nr Maidstone, Kent
    I agree, VAG-COM will show if there are any communication problems between the ECU and the Haldex controller. Thats what I would expect to see.
    Have you got an ABS or Traction Control light on the dash?
    Remind me is fuse 31 one of the ones above the battery. If not I would check them too?
    Jan 2007
    berkshire, Reading
    1,062
    no its the one one in the car. could it be one of those fuses then?! Are you about the weekend at all dave could you have a check over for me?! If it was low on oill would that cause it not to work?
    Jan 2007
    berkshire, Reading
    1,062
    oh and no lights on the dash have come up!
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    I'm about the weekend Ed, if you make your way over to mine I'll check it for you no problem. Send me a PM.
    Dave
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,592
    Talking
    Quote Originally Posted by Dave_Bayern View Post
    Dave
    I recommened you take it for a quick spin also and give us some feedback Dave.
    Longman's Avatar
    Jul 2007
    Nr Maidstone, Kent
    Yeah, let us know how you get on.
    One of the large fuses under the bonnet over the battery is for ABS/TC communication. I looked at Ballcrushers car on here with a communication prob to the Haldex and ABS and it was a connection to that fuse that was shot.
    Well worth a check.
    V/C will show this anyway.
    Jan 2007
    berkshire, Reading
    1,062
    Checked the fuses on top of the battery they were all ok! Guess we will have to see what VAG COM says!
    Jan 2007
    berkshire, Reading
    1,062
    well dave check the vag com and after he cleared everything, no other faults came up. Still only front wheels drive tho. So i changed the haldex again for the standard one and changed the oil still not working! If its to low on oil would stop it working? Any other ideas?
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Only thing that came up on yours was brake light switch - intermittent.
    However, it also came up under the AWD control module, is that something that affects the haldex operation?
    Jan 2007
    berkshire, Reading
    1,062
    what is the AWD module?!
    Dave B's Avatar
    REALITY?.... WHERE AM I AGAIN?.... WHO AM I AGAIN?
    Apr 2007
    Oxfordshire and Sofia
    176
    Could it be that the AWD/Haldes systems can't see the brake applications to read how to apply 4wd ratio's?
    Dave
    Silver S3 OE03, PH sticker in Rear Window,
    Feb 2004
    2,036
    Well if the hadbrake is aplied, the handbrake has a switch which disables the haldex.
    Maybe its the same with the foot brake.....?
    Longman's Avatar
    Jul 2007
    Nr Maidstone, Kent
    Edward: AWD moduile is what controls the 4wd system (All wheel drive)
    I would definitely start with the brake light switch if it has come up on both controllers. It would make sense for it to diable the haldex if there was a problem like that.
    Its under the dash behind the pedal.
    Jan 2007
    berkshire, Reading
    1,062
    but the brake lights are working fine! They were playing up before, so i adjusted it and works fine now!
    Jan 2007
    berkshire, Reading
    1,062
    Quote Originally Posted by Der Teufel View Post
    You should buy an Alfa mate, much nicer looking that than the fat german barges built by AUDI.
    Then i would always have problems!!
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    Are we getting BORED again?
    Cheers,
    Alistair
    "Why don't you listen to something really classical, like Mozart, Mendelssohn or Motorhead?"
    Arnold Rimmer, 1988
    Commuting & Weekend Fun:
    Yamaha YZF-1000R Thunder Ace in Blue/Black
    Practical Alternative (Still fun though!!):
    S3 2002/51 AMK Silver, Symphony II + Bose + xCarLink + AndyMac Stealth Sub, Metallic Mirrors, Heated Black Leather, Cruise control.
    scott_johnson's Avatar
    Audiless
    Bingley
    875
    Ed, how did you remove the haldex controller. is it easy???
    Jan 2007
    berkshire, Reading
    1,062
    it is if you have a ramp and a ratchet with a pivot on the end other wise it can be tricky getting to the top bolt! I used a small allen key the first time! Why do you need to take yours off?!
    Audiless
    Bingley
    875
    got a fault thats always there from vagcom. haldex memory controll error. Was goin to wack it off and see if there was anything up with it!!
    Jan 2007
    berkshire, Reading
    1,062
    it would prob be a electrical prob with it, and i guess the only way to sort it would be a new controller or get someone to repair yours!
