AH FabricationsJMB Retrofits
    Apr 2008
    one working beam
    hello good people, my first post here although i have used it for as a reference since i bought my first audi. 99 A3 1.8T. my current problem is that i only have one working full beam. all other lights are working as they should, i have bought new bulbs and also swapped from one side to another and there is obviously no power there.
    i have searched the forum but found no similar problem. any help greatly received.
    Nov 2006
    Cambridge
    90
    Fuse, relay, wiring, or bad contacts where the bulb sits... has to be one of those.
    Have you got a good multi-meter?
    Apr 2008
    A friend is going to lend me one tommorrow, it just seemed a little unusual to me and i wondered if it was a common occurance. i had a quick look and the contacts look fine however it seems there is no power. i doubt it would be anything to do with a fuse with that being the only leccy failiure? unless im mistaken.
    Apr 2007
    297
    If its the same as S3, the headlights have their own 'ECU' and they sometimes go wrong. Pricey to replace apparently. But as i understand it, they just keep blowing bulbs so odd that you seem to get no power at all?
    Nov 2006
    Cambridge
    90
    Quote Originally Posted by Tony spian View Post
    Don't quote me on this, but I would imagine that each headlamp has it's own fuse/relay?
    If one main beam is working, then it's highly unlikely to be a switch. Best way is to get your meter and start testing!
    Nov 2006
    Cambridge
    90
    Quote Originally Posted by Spacecowboy View Post
    S3's have Xenons, the 'ecu' part is probably the ballast. Yes they can be expensive.... however I would be very suprised if standard halogens have such a thing. Most likely fuse or relay.
