Monster MotorsportEM Tuning
Results 1 to 8 of 8
    Mar 2004
    Worcestershire, UK
    48
    Suggested AUDI - VW Specialists????
    Hey all,
    My Audi is causing me some grief and could do with some sort of investigation, but i don't really want to take it to AUDI garage at the charge of 75 Per Hour just for an inspection. Any suggestions would be great and even better if based in the Worcestershire - West Midlands area would be great.
    PROBLEM WITH CAR :-
    When the car starts from cold everything is fine except from a small movement in the REVs moving up and down (not stable), but when the car is warm and you turn off and try and restart it has difficulty starting, requires alot of pumping of the throttle and once started the revs hold at 2000RPM and takes a while to drop back down to normal tick over (30mins or so)
    Any Advice would be great.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,416
    Re: Suggested AUDI - VW Specialists????
    Check the coil packs and the MAF.
    otherwise,
    AMD! in Bicester near Milton Keynes are great and the guys there are Audi trained.
    Mar 2004
    Worcestershire, UK
    48
    I may sound stupid but what do mean by MAF? and where and what would i check lol,
    Sorry i'm dim, Just getting to grips with the A3.
    Thanks for the advice thou. [img]/ubbthreads/images/graemlins/smile.gif[/img]
    AndybS3's Avatar
    Jun 2003
    Central Scotland
    233
    Also try the coolant temp sensor, you need to find someone with VAG-Com neer you
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,416
    Mass Air Flow.........it is bolted to the air box and monitors air temp, air flow etc. If faulty, it could be the reason for your odd revs etc as it can not calculate the air to fuel ratio to allow the engine to run properly.
    If a coil pack is gone it will also make the engine run like a bag of S##T and make the exhaust smell of rotten eggs etc
    dbm
    dbm's Avatar
    Preston, Lancs
    483
    You could try Awesome GTi. They do all my specialist work and are great.
    Cheers,
    Dan
    Mar 2004
    Worcestershire, UK
    48
    Right, Cheers. Don't think it's the coil packs the exhaust is fine and the car runs well once started, Must be either 2 things then, MAF or Coolent Temp Sensor.
    Whats the part that the air intake connects to at the top of the main engine contact?
    The seller told me it could be a stiff component in the top engine component???
    Mar 2004
    Worcestershire, UK
    48
    FOUND ONE
    http://www.motorvation.org.uk Based in Evesham in Worcestershire if any of you are interested.
