Chris NottEM Tuning
Results 1 to 14 of 14
    Jan 2005
    Norfolk
    304
    Rear washer jet > stopped working > HELP!
    Rear washer jet packed up about 3 days ago -
    - pipe has not detached at the wiper motor and no leakage at joint
    - both pipes (for front and rear) still connected to pump at resevoir
    - with pipe detached from wiper motor and pressing stalk to pump water, slight air bubbles form out of the end of the pipe, but no fluid
    - when you blow (hard!) from the wiper motor end, you can hear a very slight noise or air at the washer resevoir (but no bubbles coming up in to the washer fluid, in the resevoir)
    - have checked below the central locking unit/sub/alarm siren, in the rear passenger-side quarter, and there doesn't appear to be any fluid laying around
    - no wet patches appearing in the interior ceiling of the car and no evidence of water anywhere/damp patches
    so........
    am I right in thinking the pipe from the resevoir to the wiper motor is only unbroken other than a join in the rear passenger-side quarter
    and
    what is the exact path from the front to the rear, of the pipe???
    and in light of all the above, ANY ideas???
    all help much appreciated!
    Jun 2003
    World of my own
    9,813
    Have a poke about in the front passenger footwell as I think there's a join behind the side kick panel in the footwell. The carpet will soak up large quantities of water before it becomes obviously wet.
    Alex Turner
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    Quote Originally Posted by AndyMac View Post
    same goes for the sub area I guess...just run the pump for some time and see if water leaks in the rear quarter...
    I took a while to notice mine. then i decided to take the bits out near the sub and check...it was actually there
    or check this thread:
    Here's why some people's rear wash/wipe.....
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    in the S3 there is a join behind the air filter box in a s shaped conduit. You have to remove the air box , maff and top strut brace to get to it. Mine showed up as a puddle under the front left wheel.
    red to red black to black blue to bits
    Redhot006's Avatar
    Standard A3 1.9 TDI 110bhp
    Nov 2007
    Crewe
    44
    Mine showed as a puddle under left wheel, the above works. Mine also blew underneath the sub when i reconnected it. Then i found out the copper pipe they use to port the water through the mechanism by the motor had sheered off on the wiper arm side. This made it p*ss the washer fulid back into the wiper mechanism and fecked the motor. So i'm looking for a whole replacement, not cheap and most of the ones at the scrappy are fecked in the same way. So be careful if you aint used it for a bit, it could have seezed.
    Jan 2005
    Norfolk
    304
    Fixed! it was the joint behind the air filter, within the piece of conduit
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Mine just did this again (for the fourth time)! I'm getting quite good at removing air filter etc. etc.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    thats me
    Sep 2004
    west yorkshire
    3,762
    mine won`t do it again as I taoed that joint together
    Feb 2004
    2,036
    MIne is leaking behind the bose sub! It looks a right pain in the arris to strip it all out and hook it back up again!
    Bloody VAG cars, my mk4 did it under the headlining at the back a couple of months back!
    Redhot006's Avatar
    Nov 2007
    Crewe
    44
    It is a pain in the harris, you have to flip the seats forward and take that side boot panel off, to get the sub out to then get at the pointless join.
    Jun 2006
    712
    it's pretty easy, rear LH seats out, boot carpet out, rear boot plastic out, then you can see the fixings for the side panel. remove all that then few screws for sub, takes about 20 mins max
    Redhot006's Avatar
    Nov 2007
    Crewe
    44
    Easy, but why have a join there in the first place, i think i remember it being taped up along side wires!
    Sep 2006
    Sunny Suffolk
    552
    I had to reconnect the joint behind the air box today. However, having reconnected the pipes the washer still isn't working. Surely two joints wouldn't have gone at the same time would they?
    Where should I be looking next?
    ICE
    Redhot006's Avatar
    Nov 2007
    Crewe
    44
    Quote Originally Posted by Redhot006 View Post
    You must have a blockage and the pressure is forcing them apart? Mine wer both gone as metioned above.
