Sky InsuranceAH Fabrications
Results 1 to 12 of 12
Thread: s3 immobilised?
    Donnie Mac
    Feb 2008
    Inverness
    54
    s3 immobilised?
    hi guys, i disconnected the battery of my 1999 s3, and once reconnectd, i tried to start the car but it wont go, it starts for a sec then dies. is there a way i can fix this? worried cos i wont get anyone in audi til tuesday probably! help please!!!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,881
    Very odd, I've had the battery go flat on my S3 a few times due to lack of use, and even changed to a new battery, so disconnected for 30 minutes or so, and no ill effects. Have you tried the spare key?, failing that, it's new ignition barrel time I think.
    You've got to have a laugh!
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,634
    you sure its your S3?
    Donnie Mac
    Feb 2008
    Inverness
    54
    yes it is definately mine! tried the spare key, 'workshop' key, and even the plastic one! none of which work. i had the battery disconnected for about an hour as i had the clusters out. the orance light (of a car with a key on it) just repeatedly flashes when i put the key into the ignition.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,881
    Quote Originally Posted by d18ony View Post
    OK, you never mentioned the clusters being out bit, now what did you do with the clusters, it's part of the immobiliser, so messing around with this part is a nono. Hope you get it sorted soon.
    Donnie Mac
    Feb 2008
    Inverness
    54
    i removed the clusters completely! i didnt think for a second this would have anything to do with the immobiliser. i disconnected the 3 wire connections at the back of the cluster. gona phone an audi specialist tomorow and see if he can shine any light on the sitation. hope i havent just cost myself hundreds!
    h100vw's Avatar
    Aug 2006
    Down South, next stop Antarctica
    215
    Make sure the cluster is plugged n properly. The key reader, ECU and cluster all need to be connected to knock the immobiliser off.
    Gavin
    Mar 2005
    Scotland
    91
    Quote Originally Posted by jojo View Post
    hey jojo why did you mention the barrel?? do these 'go' on the S3?
    reason i'm asking is the gf had a problem with the car today. says she couldn't turn the key!? I had a look at it and it seems fine to me.
    Tastyterrier's Avatar
    Monkey Trainer
    Jul 2003
    Staffordshire
    341
    Wouldn't have thought it'd cost you hundreds, you'll just need Audi to get your key's re-coded to your car, as long as you know someone that can drag you car down there tomorrow - or go to a VW dealer, it's cheaper!
    A3 1.8TQS: Supersport Springs and Shocks, Xenons, BMC Filter, 18" OEM TTV6's, Bailey DV, N75J and Phase 1 Custom Code.
    Donnie Mac
    Feb 2008
    Inverness
    54
    took the clusters back out tonight and checked all connections. seemed fine but when i plugged all back in away it went, one wasnt getting a good connection somehow, even though it was plugged in properly! think that will be the end of my DIYing on the audi! has anyone ever got the lcd screen on the clusters replaced???
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,881
    Quote Originally Posted by colinra View Post
    I remember reading these 'go' as you put it in some A3's, I'm thinking the S3 is the same part.
    grathies's Avatar
    More Points Than Portsmouth FC
    Dec 2004
    Portsmouth, Hampshire
    1,355
    The actual switch part that sits behind the barrel does go, probably the same number that they use on the Golfs!
    Wouldnt imagine it was that it if it was fine before taking out the cluster tho
