Chris NottMonster Motorsport
Results 1 to 8 of 8
Thread: Dump valves
    rhubarb4's Avatar
    Certified Jardo Slayer
    Mar 2008
    Midlands
    1,715
    Question Dump valves
    Hello everybody. I have an audi S3 2000 model, i want to know if fitting a Forge splitter dump valve can affect the the boost on the car for example on acceleration, experiencing a jerking like taking your foot on and off the pedal quickly. As iv been told my coil packs seem ok its the only other thing that has recently been fitted to the car that was not standard.
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,715
    anybody
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,715
    bump
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,291
    Checked the MAF?
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,715
    no not checked the maf what is it and where is it. So you reakon its not the new dump valve then
    Tastyterrier's Avatar
    Monkey Trainer
    Jul 2003
    Staffordshire
    341
    Maf:
    Could also be leaking boost hoses, a dodgy spark plug, N75 valve, N249 Valve. fuel pump etc etc.
    You'd be best to get your error codes read. Find a friendly VAG specialist.
    A3 1.8TQS: Supersport Springs and Shocks, Xenons, BMC Filter, 18" OEM TTV6's, Bailey DV, N75J and Phase 1 Custom Code.
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,715
    hi thanks for the photo I went to a local garage where they put it on something called Vagcon and it said there were no faults
    Monkey Trainer
    Jul 2003
    Staffordshire
    341
    Have you still got your original recirc valve? You coul run with that for a while and see if the fault still occcurs.
    If the fault is happening all the time, try disconnecting the MAF and running the car you a couple of miles. If the problem disappears, there's your problem
