JMB RetrofitsEM Tuning
Results 1 to 37 of 37
Thread: DV/N249 help
    NoggyDS3's Avatar
    Oct 2007
    Scotland
    193
    DV/N249 help
    Got a custom code phase 1 remap the other week and also replaced the standard dv with a forge 007p. Sometimes the car has no boost and feels like there is no turbo. If i turn the car off and on again its fine!
    The 007p was stuck closed so i took that off and put the standard one back on but the problem is still there.
    Got it on VAGCOM today and got the following errors:
    17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
    P1200 - 35-10 - - - Intermittent
    17705 - Pressure Drop between Turbo and THrottle Valve (check D.V.!)
    P1297 - 35-10 - - - Intermittent
    Can anyone shed any light - what does this mean? Is it the N249 that needs replaced? How easy/cheap is this to replace?
    Sorry for all the questions but any help much appreciated!
    2001 Facelift S3, Custom Code Phase 1, Forge 007p
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    The N249 is a protection device. It has the ability to open the DV via the vacuum reservoir if required by the ECU.
    The map should be good and may have highlighted an issue with the N249? You can disconnect the valve mechanically if you want to eliminate it, but that code sounds pretty straight forward and sounds like it needs replacing.
    NoggyDS3's Avatar
    Oct 2007
    Scotland
    193
    Thanks! do you know how much it costs and whether its simple enough to replace?
    jesters3's Avatar
    The Shire's
    1,516
    N249 for a BAM engine part code is 078 906 283N
    Had the 17705
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    jesters3's Avatar
    The Shire's
    1,516
    Had the 17705 Code on mine and it turned out to be a split on a oil carrier hose off the TIP. So check all main and minor hoses for splits or looseness.
    Jester
    NoggyDS3's Avatar
    Oct 2007
    Scotland
    193
    Thanks - mine is the AMK, will it be the same? i'll get all hoses checked too. cheers
    Tastyterrier's Avatar
    Monkey Trainer
    Jul 2003
    Staffordshire
    341
    Looks like I have the same problem on mine, identical in fact. Custom code, loss of boost, next time I turn the key it's back! I get the same codes too.
    I know the N249 valve in on top of the cylinder head on the S3's, but where is it on my TQ? Anyone know the part number for an N249 for a ARY engine?
    A3 1.8TQS: Supersport Springs and Shocks, Xenons, BMC Filter, 18" OEM TTV6's, Bailey DV, N75J and Phase 1 Custom Code.
    scott_johnson's Avatar
    Audiless
    Bingley
    875
    I have exactly the same problem in the morning. Mines a revo though... sure its nothing to do with the map though. My car originally had a baileys dv on which broke so a normal 1 was put on...... i get the same code '17705 - Pressure Drop between Turbo and THrottle Valve (check D.V.!) P1297 - 35-10 - - - Intermittent' nothing about the n249 though....... is it worth having a pressure check to see if anthings leeking???? + change the DV?? cheers
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Just replaced the N249 on mine because i was getting this same fault code. BAM Engine.
    Part No 078906283A 45.79 + VAT
    2007 A3 TDI 170 S Line
    Sold - 2002 S3
    Audiless
    Bingley
    875
    wat was the cars symptoms steve?? did it sort it out??
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    could be the problem i m having although mine is always down on power & seems to just splutter & hesitate no engine or anything ;-(
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Quote Originally Posted by scott_johnson View Post
    Didnt really have any noticeable symptoms, it was just flagging an intermittent fault when i vagcom'd it. The fault hasnt come back since i changed the N249.
    Sold - 2002 S3
    NoggyDS3's Avatar
    Oct 2007
    Scotland
    193
    Had the N249 and a new forge 007p fitted (after checking that this one worked first) and I still seem to have the problem!! Car runs perfect after i turn the ignition on and off again though! Anyone got any ideas???!! Help!
    Monkey Trainer
    Jul 2003
    Staffordshire
    341
    Sorry to ask this question again but I'm stumped, done a search on here and googled it but I still can't find the answer. Anyone know where the N249 is on an A3 T? A mate reckoned it was near the dipstick in front of the block, before I disassemble the mess of wires/hoses, can anyone confirm this?
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Its underneath the plastic engine cover, at the front righthand side as you look at it mate.
    Sold - 2002 S3
    Monkey Trainer
    Jul 2003
    Staffordshire
    341
    Yeah, that's on an S3, doesn't appear to be in the same position on my TQS
    Feb 2008
    529
    tatsy - your will probs be in the same place as mine (AUM), where the dip stick is theres a black plate with two sensors attched on the underside of it, its one of them.
    Audi A4 Avant 1.9TDI Quattro Sport 2004
    Feb 2008
    529
    does the N249 have another name? cause i went to my audi last week to order one and they didnt have a clue what it was.
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Its also called a Solenoid change over valve.
    Sold - 2002 S3
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    I believe all the A3/S3 use the same P/No: 078906283A
    Sold - 2002 S3
    Feb 2008
    529
    ok cheers, i might take mine off and get the number from there to be on the safe side bud.
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Thats probably the best idea then you can just order it by P/No, I had the same issue when i ordered mine had to show them where it was on the diagrams.
    I always find http://www.vagcat.com/ useful for checking/finding part numbers
    Sold - 2002 S3
    Feb 2008
    529
    cheers i'll have a look through that
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    think i have the same problem, here is my fault code
    Address 01 -------------------------------------------------------
    Controller: 8N0 906 018 BH
    Component: 1.8L R4/5VT 0001
    Coding: 10710
    Shop #: WSC 01236
    1 Fault Found:
    P1200 - 35-00 - -
    Readiness: 0000 0000
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    guys, i dont know if your interested but i have found that my fault code is down to a T piece that connects 3 pipes on top of the engine... the piece is prone to breaking according to the mechanic i use..... was about to change the solenoid valve too
    NoggyDS3's Avatar
    Oct 2007
    Scotland
    193
    Got it on Vag Com again today, the N249 fault code has now gone so the new N249 must've done the trick. However, the pressure drop between DV and Throttle fault code is back, despite a new DV being fitted so thats not the problem. Had a quick look around for any obvious split vaccum hoses but couldn't see anything out of order and it's still got no boost in the morning until i turn the engine off/on again then its fine! Getting it booked in next week so they can do some logging to see if that throws up anything.
  28. #27
    Monkey Trainer
    Jul 2003
    Staffordshire
    341
    Just as a quick update, I took my car to my Audi Guru today. He read the car and it showed no faults. He then took it for a blast and said there was a definate hesitation, like a loss of boost. Using some boost detection spray(? - not sure what this is, apparently it shows up where boost pipes are leaking) he went round the whole engine bay, nothing was leaking.
    He then came up with a possible reason for the problem, apparently as the car is remapped and it's running standard plugs, a weird thing can happen where the extra force of induction can blow out the spark (yeah, I can see you shaking your heads from here but at this stage I'll try anything), so he recommends replacing the plugs with some good quality tri-spark types. I'll let you know how I get on.
    Also he was saying that he had all sorts of problems with non-Rosstech cables when using Vag-com, with false codes being thrown up and issues with them not fully removing codes from the ECU. Just something to think about fellas (and ladies if there are any still on here!)
  29. #28
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    just as an additional matey...... my little T piece that needs replacing requires a whole fecking piece of pipe.....looks a nightmare to fit..... took me ages to work out from the ETKA diagrams which one it was that had gone!!
  30. #29
    Feb 2011
    southampton
    229
    i have got this 17608 code so replaced the n249 tonight clear the code start engine dont rev it and code is gone so switch it of start it up and rev it then plug vagcom in and code shows up again its very annoying .. any suggestions
  31. #30
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,337
    Quote Originally Posted by Tastyterrier View Post
    thats were mine is i have a TQS when u lift the engine cover of it should be covering the 3rd and 4th coil pack
  32. #31
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,458
    Quote Originally Posted by karls s3 View Post
    17608/P1200/004608 - Ross-Tech Wiki
    That code is normally thrown when the ECU tries to use the N249 to dump boost but the ECU can't detect a drop in boost pressure from the MAP sensor... this has been known to happen on bad remaps and/or if you have bypassed the N249... the N249 is used by the ECU to dump boost when it thinks it has detected a problem so uses the N249 and the vacuum store (the black tank next to it) to operate the dump valve even when on boost...
    Its not an electrical issue as thats a different code...
    Are there any other codes coming up?
    <tuffty/>
  33. #32
    Jul 2010
    111
    i get this issue as well, feels like no turbo then turn it off and back on again and full boost. I have done the N249 bypass mod though?
    2001 S3 AMK. Viper Remap, Forge 007P, Carbon fibre engine cover, SFS TIP, Tints, Forge Breather Hoses, Auti R8 oil Cap, Leon CPR Top mounts, S3 car mats, German number plates. 249 By Pass mod
  34. #33
    Reesy's Avatar
    East Sussex
    3,604
    IOM-S3 - I had a similar problem when I got my A3. Mine was down to the map I had on it, It was an older map and when giving the car the beans, it would effectively send the car into a safe mode, where the car would feel like a non turbo (with no lights on the dash), if I pulled over, turned it off and back on again it was fine. Since had it re remapped and it has never done it since.
  35. #34
    Jun 2009
    Woking, Surrey
    131
    Quote Originally Posted by IOM-S3 View Post
    Same thing happens with mine. Oddly it has stopped doing it recently. I'm putting it down to the cold weather. It would also only present the fault code from a cold engine. Once warm it would never appear. Very strange, but clearly something to do with the N249 bypass I would say.
    2001 (Y) Audi S3 AMK | Forge 007p | H&R ARBs | Powerflex Bushes All Round | Badger5 3" TIP & Jetex JR Filter | R-Tech Stage 1 Map | Brembo 4-Pot Callipers (Monoblock from Clio 197) with Ferodo DS2500 & EBC Ultimax Discs | N249 Bypass | Milltek Cat Back Non-Res Special Tips
  36. #35
    Jul 2010
    111
    cheers reesyboy and hadders, thing is it will do it without me even going into boost, so like if i drive 5-10 miles just going slow and at low rpm it will sometimes just not boost?
  37. #36
    Jun 2009
    Woking, Surrey
    131
    Yup. Sounds about right. As I said though, mine has kind of disappeared with the warmer weather. Even stranger!
  38. #37
    Feb 2011
    southampton
    229
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    only that code mate 17608 and p1200 got a dump valve to try as it says on ross tec could be dv or valve n249
