Programming Spare Key Problems!!!!
DEL BOY
Hi,
I have a 2001 Audi A3 1.8SE
I am having some trouble programming a NEW spare key.
I can get the doors to lock and unlock, but when you put the key in the ignition it doesnt seem to recognise the immobliser - fires up then cuts out immediately.
Old key
4DO.837.231. a 211.01
433.92 Mhz
New Key
4D0.837.231A 14.01
433.92 Mhz
Am i using the correct key?
Can anyone suggest why i can't get this to work or help at all.
Thanks in advance
Derek
I thought its main dealer / vag com only to get the key to work with the immobiliser
If anyone can comfirm this i will go to audi and stop wasting my time lol
Thanks for the reply!
i've done this once before on a mk4, if the process is the same then you need a skc code either 4 or 7 digit depends on the age of the car. you then need to program the key into the immobolizer using this code
i had the same prob with may old golf mark4 got the info of web to sort it out
If you still have the original white plastic tag with a scratch of panel then the secret key code is under there. VW/Audi used to supply the codes to owners but not any more. Anyways you need to log into the immobiliser via vag-com with this code to programm the new key in.
10
Nel
811
MPH
906
AA3
913
