JMB RetrofitsVolks Autos
    dantdi's Avatar
    Feb 2008
    kent
    511
    back window washer
    Any one had problems wit back window washer? Not had chance to look at mine yet. can hear the motor running but thats it. Any one took there tail gate inside panel off? if so how easy ?
    Dan
    S3 chj's Avatar
    Nov 2007
    South Wales
    296
    its very common mate, have a read through this .Here's why some people's rear wash/wipe.....
    S3 mods and tuning in progress
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    did you check in the rear quarter panel inner arch for fluid loss? if it is there, then it might be the pipe got disconnected under the sub unit...
    I had the same problem...check this pic:
    this might also help
    Jun 2006
    712
    haha, isn't that my car?
    Feb 2007
    19
    I am having the same problem myself, i took apart the boot and all i could find was what looked like a pump (wrapped in a foam type block) it had a pipe in and a pie out? is this a secondary pump? i had no joy anyway. unless that is a waterpump and has gone faulty. i have checked the connection to the wiper motor and that is fine. it is wrecking my head
