Volks AutosChris Nott
Results 1 to 10 of 10
    Mar 2007
    74
    Where is the fuse box in my A3?
    Hi,
    When using my indicators they work but they also cut off themselves and i have to indicate again. This is continually happening. I am trying to locate my fusebox in my A3. Does anyone know where this is? (its on a 52 plate).
    Thanks.
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    there is a panel on the side of the dash (drivers side) as you open the door, the fuses are behind there
    Mike
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    Mar 2007
    74
    Thanks, i just found that. The reason i wanted to know where the fuse box is located is because in my MK2 Golf there would be a relay there and that was normally the cause of the problem. I cannot see a relay here.
    Does anyone know what is causing me this problem? The indicator works fine sometimes, it cuts of other times, and sometimes when the indicators are on the pattern is rather strange. Also in the fuse box compartment there is big sticker which contains numbers for each type of fuse. However i cannot figure out which number is for which fuse?
    rodenal's Avatar
    Oct 2006
    1,982
    The numbers can be found in your handbook - it doesnt sound like a fuse issue to me tho, more likely the stalk itself i'd say
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,641
    Sounds like it may be the relay
    Jun 2003
    World of my own
    9,813
    The relays are under the knee bolster on the drivers side.
    Alex Turner
    Mar 2007
    74
    I thought it may be the relay but the hazards seem to be working??
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Do the indicators remain on when the car is stationary? Has it anything to do with how the steering wheel is positioned?
    simonwjones's Avatar
    Aug 2005
    staffs uk
    344
    The hazard warning switch has dual relays for the indicators and the hazard switch.
    9 times out of 10 strange indicator problems are caused by the hazard switch.
    Simon
    A6 2.5tdi Quattro Sport 180
    A6 1.9tdi Avant ................. Gladly missed
    A6 2.8 Quattro .................. Sadly missed
    Quattro 2.8 Coupe ............. Sadly missed
    RNS-E, Audi BT, Phatnoise
    Mar 2007
    74
    Thanks for that, it was the relay. I read an old post here and it said the hazard switch has 2 relay's. One for the hazards and one for the indicators. I replaced the hazard switch which contains the relay's and it solved the problem.
