Service
rickparmar
DIS has come up for a service in 100 miles,
i shall be doing this myself, the car has done approx 88k
What do you all recommend i should change,
Its on a long life service at the mo, and the haldex oil was changed about 60k ish
Probably brake fluid, oil, air and pollen filter, the oil, spark plugs, check brakes, i think thats about it, if i understand correctly of your message....
cheers mate
spark plugs, never thought of that - which ones should i get ?
brake fluid is ok as the clutch etc just got replaced recently
Never done haldex before, is there aguide where to drain and replace the oil and filter
Sorry cant help you on the Haldex, as for the Plugs, there are quite a few different ones and im sure people will have their own preferences, champion, ngk, bosch, the choice is yours.
704
716
831
