Badger5Monster Motorsport
Results 1 to 14 of 14
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    Dog bone thingy ?
    Is this standard kit on an Audi S3 ? am i right in saying it fits to the gear box & engine to reduce movement & increase more precise gear changes ?
    Matt
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    ash_s3's Avatar
    Aug 2006
    Shrewsbury
    1,005
    Just reduce movement mate i think, wont alter gear changes
    Its just a replacement poly bush as the standard ones are softer rubber.
    You'll find your standard one between your gearbox and subframe (IIRC)
    2001 Audi S3 l MTM Remap l 252.7bhp 432.4Nm l Forge 007P l ECS Porsche Stage 2v2 Front Brake Set-up l ECS Stage 1 Rear Brake Set-up l 18" RS4 Alloy Wheels
    ash_s3's Avatar
    Aug 2006
    Shrewsbury
    1,005
    You only get the yellow bit (poly bush) the rest is your standard bits
    Nov 2005
    UK
    1,688
    oh right i see so is it worth the bother ?
    wanted for 8L S3:
    Milltek system
    ash_s3's Avatar
    Aug 2006
    Shrewsbury
    1,005
    Meant to be yeah, not used one myself though so i cant really comment!
    Jun 2006
    712
    i spent ages searching for reviews of these. the conclusion was that it made things too hard, and you get vibrations at idle. The best bet is to fit a new standard one, but unfortunately it's not available seperately from Audi!
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Ive changed both bushes on my Dog bone mount for uprated ones (not just the rear one pictured above), it has actually improved the change from 2nd to 3rd (very rarely crunches now where as before it crunched most times when driving hard)which as we all know is an issue with these gearboxes.
    2007 A3 TDI 170 S Line
    Sold - 2002 S3
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,284
    Totally worth it i'd say!
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,187
    I had one on my old LCR, definately worth it, but took around 6 months to settle down and loose the vibrations. Some say setting the torque correctly helps avoid this. There's also a full mount available, can't remember who makes it but look on SeatCupra.net as loads of people on there fit them.
    It helped to put the power down better with the 2wd, I had less traction control light flashes so I suppose with an S3 you'd be losing less of the bhp to the rear wheels.
    S3 Sportback S-Tronic
    Previous
    2010 R36 Saloon in Biscay Blue
    2008 Red S3
    2005 A3 3.2 quattro S-line Sportback dsg Avus silver
    2005 A3 3.2 quattro Sport Sportback dsg Black
    Jul 2004
    Cambridge
    339
    I had one fitted a couple of weeks back. I must admit, there is more pronounced vibrations from the engine on idle. Doesn't really bother me much, as it's only very slight.
    If anything, it makes the car feel more "raw".
    Work commute:
    Honda CBR 1000RR
    169 kg & 170 bhp - eeek!
    Backdraft Big Turbo Silver S3, Supersprint, Eibach lowered, QST rear tiebars, SPA boost gauge Sold
    Lotus Elise 111R also Sold
    Wanted: Honda powered Lotus Elise S2
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,425
    Had mine fitted for about 4 years or so now, they need running in, vibrations at idle at the start, then settles down with a few k miles, still slight vibration, but nothing to worry about. Plus points are more positive gear changes due to less engine movement and better transmission of power to wheels, but I doubt you will feel this. Bad points are vibrations into the cabin, mainly steering column and steering wheel.
    You've got to have a laugh!
    S3 amd map,coilovers,upgraded heldex,lcr spliter..
    Apr 2007
    Bristol
    228
    i fiited one to my mk4 and it was a good mod, as stated it seems to tighten things up but you do get a bit of vibration.
    lox19's Avatar
    Sep 2006
    68
    I had mine fitted a few weeks ago as have been thinking about it for along time, and i am very glad i had it done. I remember someone saying ages ago that it would rattle your teeth off!!! so it put me off but have to say im glad i got it done.
    Gear changing feels alot more smoother, the crunches in 2nd to 3rd have pretty much disappeared.
    I have noticed though you have to accelerate a little higher to get the bite point otherwise the car stalls!!! But the cabin vibration is only really felt through the steering on idle just about but other than that my teeth are still in check!!!
    Dec 2006
    halifax, west yorks
    67
    i fitted one about 6 weeks ago, it does rattle a bit but is well worth it.
