Sky InsuranceVolks Autos
Results 1 to 8 of 8
    Feb 2006
    england
    29
    Squeaking brakes!!!!!!!!!!!
    My mate has a really bad squealing from his brakes. He hs changed the front and rear discs and pads but still this has got rid of it. The pads were copper slipped everywhere the pad touches the caliper and the edges were filed down but still the squesling. Do the standard audi pads have anything to do with it?
    s3ollie's Avatar
    Jan 2007
    749
    i had/have this problem with my brakes. was advised by the peeps on here to try BMW grease called plastilube i think. it worked well (better that copper) to begin with but i do get random squeaks here and there getting worse as time goes on and i only did it a few weeks ago.
    8P S3
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    when I did my discs and pads the pads stuck in place with a sticky pad all over the rear of the brake pad so just copper slipped the edges.
    don`t know if yours were the same ????
    red to red black to black blue to bits
    Feb 2006
    england
    29
    Ill try the BMW platilube and see if that helps. I was told that the OEM Audi ones do cause squealing on the S3 sometimes, something to do witht he compound. Has anyone else heard this?
    Jun 2004
    Surrey
    595
    Mine squeaked when I had them changed and I was meaning to go back and get the garage to look at them but never bothered. After about a couple of thousand miles it stopped.
    spiker's Avatar
    usually growling at something
    Jul 2005
    Thornbury
    200
    Stupidly my local mot garage offered to replace my front pads and discs - what a pain - 6 weeks on still squealing and after 3 return visits i have given up
    Next time will buy the parts myself and take them to a different garage to be fitted
    Incidentally - If I remove the wheels which parts do i grease ?
    If you aint first you're last
    Dec 2006
    190
    Some pads just squeak, nothing you can do. If you want to copaslip them, copaslip the back of pad and the ears at either end that slide in and out of the caliper.
    s3_tny's Avatar
    Jul 2005
    essex
    92
    I also get this on my rear brakes and are all genuine audi parts but sometimes they even squel slightly
    while just driving and not even pushing the brakes,
    but everytime i take them off and grease them then they're ok for a few weeks then it all starts again
    so recently changed them for some bosch ones and were fine for about 8 weeks but now starting to come back
    so i'm baffled what to try next GRRRRRRR!
