Volks AutosJMB Retrofits
Results 1 to 11 of 11
Thread: any ideas?
    Feb 2008
    529
    any ideas?
    i can be driving along fine stop at a junction or traffic so pull away nice and smooth just get moving 5mph max, so im bearly touching the accel pedal and it wants too take off, does it for a second or two then it goes back to normal.
    any ideas?
    Audi A4 Avant 1.9TDI Quattro Sport 2004
    Feb 2008
    529
    someone must know ?
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    sounds like it could be the drive by wire box on your accelerator pedal?!?! try vagcom??
    S3 - Gone but not forgotten!
    Jan 2007
    Hertfordshire
    520
    Are you pulling away in second? No offense meant but if you labour the engine it tries to bring the revs up to stop you, I get a surge now and again when the car is labouring.
    Feb 2008
    529
    nah deffo not pulling away in second, had it on vagcom, has a error 17705 presure drop between turbo and throttle valve (check dv) P1297 - 35-10--- intermitted
    h100vw's Avatar
    Aug 2006
    Down South, next stop Antarctica
    215
    That's a boost leak. Could be the DV if you are running a std plastic one. Clear the code and see of it comes back.
    Gavin
    Feb 2008
    529
    i have noticed a louder hissing noise than normal, wont be DV as its a forge and ive just replaced all the internals. is there a easy way to find a boost leak?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,561
    Did you ever sort this problem out? I have this code come up. Only seems to happen if the outside temp is 5 degrees or less. Car goes into limp mode and runs on actuator pressure only. Stupid thing is, I can restart the car seconds after it happens and all is good... I had this happen when we had the snow etc and then it went once the weather became milder. Had a frost this morning (2 deg outside temp) and its back!!!
    I have checked vac and boost pipes and have a Forge DV, sticky N249 maybe? I have also cleaned the throttle body and did a TB reset in VAGCOM.
    Any suggestions gratefully received
    Ta
    <tuffty/>
    Feb 2008
    529
    no i didnt, i ended up pxing my car in a few weeks later for a S3. sorry
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,561
    No probs mate, I have it booked in with a local expert to get the car checked over anyway...
    Ta
    <tuffty/>
    Feb 2008
    529
    hope you get it sorted
