EM TuningMonster Motorsport
Results 1 to 8 of 8
    djmotorsport's Avatar
    Glasgow, Scotland
    78
    Yaw sensor - Where is it?
    My S3 (2001) has an intermittent problem with ESP/ABS. Looking through the forum, it appears likely that the culprit is the Yaw sensor (1J0 907 657A). I've taken off the lower dashboard on both sides, but I cannot find the damn thing! Anyone know where it is?
    MarkyB has one for sale, so at least I know where to get one once I can find it :-)
    DJ
    A3 1.9 TDi
    807
    you sure its not the brake switch?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Its attacjed to the side of the steering column, quite far down.
    MarkyB's Avatar
    Bristol & Salisbury
    106
    Hi,
    your best bet is to buy/borrow a VAGCOM and check which sensor is faulty, as there are couple of sensors that can cause the EPS/ABS warning light to come on.
    Here a couple of posts that may help
    Diagnostic tools off ebay [Buying a cheap VAGCOM, you'll need your own laptop!]
    http://audi-sport.net/vb/showthread.php?t=37739
    [Replacing the] Longitudinal Acceleration Sensor (G251)
    http://audi-sport.net/vb/showthread.php?t=38175
    * this is not the part that I have in the ForSale section, which is a YAW Sensor.
    Cheers,
    Mark.
    Glasgow, Scotland
    78
    Quote Originally Posted by benr View Post
    If it was, what would be the symptoms?
    For me, the ESP and ABS lights come on at start from cold, and after about 10/15 mins, if I stop/start, they go out and stay out - occasionally come back on on bumpy roads, and the only way to clear them is to switch the ignition off/on. When the lights are on, you can spin the wheels in first and lock them under braking.
    Just managed to find the offending item (Thanks HTC) and get it out.
    DJ
    A3 1.9 TDi
    Glasgow, Scotland
    78
    Quote Originally Posted by MarkyB View Post
    Hi,
    Cheers,
    Mark.
    I'm lucky that I've got access to another A3 that I can swap parts with, but no VAGCOM. So, I'll try both of these sensors and see what's what.
    The power of t'internet - magic :-)
    DJ
    A3 1.9 TDi
    807
    Quote Originally Posted by djmotorsport View Post
    not totally sure but with mine the esp and abs lights came on and it came down to a rear break light bulb not seated properly...
    thats what made me think its to do with the brakes although im no expert..
    S3_Pricey's Avatar
    Nov 2006
    Worcester/Leamington Spa
    300
    If it was the brake switch then you would have no brake lights. this happened to my A3 shortly after gettting it
    S3, 2001 Facelift, 210bhp AMK,
