EM TuningVolks Autos
Results 1 to 10 of 10
    Feb 2007
    UK
    229
    Suspension, what first, ARB's or Springs & Shocks?
    I am gradually upgrading my car, onto suspension now.
    I would like to get some Bilstein B8's with either H&R or Eibach springs, looking to lower no more than 15mm to 20mm..
    Will also budget for some KW Adjustable Tie Bars.
    Any recommendations for springs to lower this kind of amount? Im not lowering the car for looks, more for the driving experience, as the original stuff is getting a bit crashy and worn.
    Also i have read good things about urgrading the ARB's, so 22mm up front with 19mm rear is what i would go for.
    Whats the cheapest and most effective option for these?
    And what order would you do these mods in? ARB's first? springs and shocks first? I assume it would make sense to save up and get it all done together with 1 final alignment....
    Just about to have my lower wishbone bushes changed and having also just had 2 new tyres i will be having a 4 wheel alignment soon..
    James
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,755
    i like my R32 ARB`s but not everyone agrees but for the money they are a good upgrade, I did ARBs first and am still looking into simular suspension to you.
    red to red black to black blue to bits
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Dampers first...so springs and dampers makes sense...
    Then ARBs.
    The standard ARBs are fine...just there are better options.
    The standard dampers are not fine. They are crap.
    Springs + dampers, full geometry set up, and play with the tyre pressures...
    Then add the ARBs.
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
    Feb 2007
    UK
    229
    Anyone running upgraded shocks and springs, with standars ARB's?
    Interested to know how it would drive?
    JB
    rickquattro's Avatar
    May 2003
    Rickenback, German Black Forest
    588
    If your looking for cost effectiveness, save a little longer and do the whole job at the same time. One trip to the garage and the per hourly... and reduce the "getting stuck factor" of doing one thing when its better overall to do both. I reckon the suspension will cost more than the ARB's but is less faff/cost to fit.
    The dampers and springs may help ride quality a lot where the ARB's change the driving experience/poise. Get both and be very happy!
    Glens info in the stickies is very helpful. I have the R32 ARBs, others like the H&R stuff but I have not been in the position to drive both but I am very happy with what I have.
    HTH
    Coming back to Audi with an A3 Tdi Sportback Quattro... but the 220bhp T5 was epic....
    Feb 2007
    UK
    229
    Thanks for the info guys!
    Will see how far i can stretch my budget.
    As far as geometry. I guess its best, and easiest for me as i have not got alot of experience with tweaking them, to just get them to set it up as standard?
    James
    May 2003
    588
    Assuming your dropping the ride height and your budgeting for adjustable tie bars at the rear, try a 4 wheel alignment if you can to set it up properly. Again, see the stickies....
    Let us know how you get on..
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    If you're planning on doing a full revamp of the suspension then it would work out cheaper to get it all done at once as said above, one fitting charge and one alignment charge. If you are going to do it in stages then i'd say shocks and springs first with adjustable rear tie bars and then ARBs. Bilstein B8s with H&R springs are a great setup and work really well with the H&R ARBs.
    Hope this helps and for any prices give us a shout.
    Damian @ DPM
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Feb 2007
    UK
    229
    Been thinking about it more, with the road conditions here etc, i really only want to lower it about 10mm maybe 15mm. Are there any springs that offer this kind of lowering, and would work well with the B8's?
    Cheers!
    James
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    Weitec offer 20/15mm lowering springs but most others are 25 or 30mm.
    http://www.dpmautostyling.co.uk/cata...oducts_id=2457
    HTH
    Damian @ DPM
    DPM Performance
    T: 01207 561606
