Chris NottAH Fabrications
Results 1 to 18 of 18
    May 2007
    MOT Failure - Ł400 for new headlight!!!
    Just been down to Abtech in Southampton, my S3 failed the MOT as the Adjuster on the headlight is broken. They've said the only way is to replace the whole thing, thats Ł400 for a Halogen headlight unit!!!!
    Anyone know where I could pick one up cheaper?
    Feb 2008
    529
    you try'd ebay?
    Audi A4 Avant 1.9TDI Quattro Sport 2004
    May 2007
    Yop, just come off the bay now, booger all.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,611
    http://www.partsgateway.co.uk/
    try these as they do mail-order
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    If it's for an S3 that'll include the ballast (high voltage bit) casing and xenon bulb I bet, so it's not actually a bad deal for Ł400, but you almost certainly don't need all of it which is why it's a waste.
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    Do they mean the levelling motors don't work? You can buy them for around Ł40 and they're a doddle to fit, you don't need to change the whole headlight.
    Bobt's Avatar
    Mar 2007
    Hertfordshire
    56
    If the self leveling motor level drops after driving for a while just start car up so the beam is level then disconect the motor lead from headlight..
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    Could get a brand new headlight for Ł70 ish from most auto factors.
    Built in Germany, Perfected in England
    joost's Avatar
    Nov 2005
    Lancs
    1,166
    Try here too...
    Justin
    2001 VW Golf 2.3 V5 (170) Highline, Indigo Blue - standard, for now...
    A4 (B5) SE with a few slight amendments here and there (sold)
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Quote Originally Posted by Randomjim View Post
    Not for the facelift S3, trust me i tried before coffing out for my new one. They are Ł480 from Audi, i managed to get a quote of Ł400 from VAGPARTS and then got a dealer to price match this.
    2007 A3 TDI 170 S Line
    Sold - 2002 S3
    Dec 2006
    190
    As someone said before, i think you can buy the motor seperate from the headlight itself and it just twists in.
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Quote Originally Posted by dan_a3 View Post
    Yes if its just the motor thats gone. I believe the part number is 8L0941295B. When i had to replace mine it was the mechanism inside the headlamp that was broken ( caused by a coming together with a pheasant at about 70mph) not the motor so had to replace the whole lamp
    Sold - 2002 S3
    May 2007
    Ah ha, advert on ebay for a bloke breaking an S3 that's been rear ended, just bagged a headlight unit for Ł160.
    All front parts available chatting to the bloke, its a 2002 face lift S3 he's breaking.
    May 2007
    Jul 2004
    Cambridge
    339
    When my headlight hit the ground, it was the mechanism inside the headlight that the motor spins inside that was disconnected.
    You should check that, and the motor before replacing the headlight.
    You can replace the motor quite easily as I understand, but to check the mechanism inside the headlight will require it to be removed, which is a bumper off job....
    Work commute:
    Honda CBR 1000RR
    169 kg & 170 bhp - eeek!
    Backdraft Big Turbo Silver S3, Supersprint, Eibach lowered, QST rear tiebars, SPA boost gauge Sold
    Lotus Elise 111R also Sold
    Wanted: Honda powered Lotus Elise S2
    Jun 2006
    712
    (shamless plug) i've got brand new boxed genuine S3 facelift headlight if anyone needs one, complete with all bulbs, Ł195
    although knowing my luck as soon as it's sold i'll need it....
    grathies's Avatar
    More Points Than Portsmouth FC
    Dec 2004
    Portsmouth, Hampshire
    1,355
    Ahh good old Abtech....
    Jun 2006
    712
    you love it
