Urgent help needed regarding HALDEX controller....Vagcom
scott_johnson
UK
Address 01: Engine Labels: 8N0-906-018.LBL
Part No: 8N0 906 018 J
Component: 1.8L R4/5VT G 0004
Coding: 10710
Shop #: WSC 80179
WAUZZZ8LX21002834 AUZ7Z0A1887012
2 Faults Found:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 - -
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-00 - -
Readiness: 0000 0000
Address 22: AWD Labels: 02D-900-554.LBL
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
2 Faults Found:
65535 - Internal Control Module Memory Error
00-00 - -
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 56: Radio Labels: None
Part No: 8L0 035 195 H
Component: symphony II NP2 0151
Coding: 00201
Shop #: WSC 00000
2 Faults Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
44-10 - Short Circuit - Intermittent
00856 - Radio Antenna
36-10 - Open Circuit - Intermittent
Any 1 any ideas...... most importantly the haldex controll unit?????
i had the 65535 code with my air bag module and i had to replace it
Clear the codes and try again in a few days, could be old codes not been wiped-off?
Doesn't look good though!!
Is your haldex fault not the brake light switch fault?
The handbrake and foot brake have switches which ( certainly the handbrake switch) disengage the power to the back axle. I would check and replace both the handbrake and footbrake swiitches first and go from there, then clear the codes and try it again.
Does your haldex work? Try a quick start in the wet or damp, there should be no front end wheelspin. If it seems to grip and not spin, gently pull the handbrake up a notch or two so the light shows on the dash then try a quick start too. The haldex should be disengaged and the front end should spin up quite easy in "FWD mode".
The brake light switch came up as i had a brake light out (been replaced now) or so i think thats what it was. As for the quick start... ive already tried that and no wheel spin what so ever. its running 100% ill have a look on vagcom wiki...
Try just clearing it, if haldex is working that is a good start!
I was under the impression that the Haldex had it's own ECU and could not be scanned by VAG.com? In this case I agree with smich it is more your brake light rather than the Haldex playing up.
on your 17705 one, Do a REALLY GOOD search around your hoses for leaks or splits in the pipes, pull apart ones that are together and have a look inbetween. Had the same code and found the split hose hidden between two that 'brushed' against each other, it was the oil carrier hose coming off the block 06A 221 103 BG cost £29 from Audi, 10 pack of clamps from Halfords £3.49 and 2 mins to fit.
600
842
806
14
