Chris NottSky Insurance
Thread: Creaking
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Creaking
    Right,
    Got a really annoying creak at the passenger side front wheel. Its only once its warmed up a bit, and at low speed braking (like under 10mph..may be more but this is only time i can hear it), and when moving off from a standstill. What coudl this be????
    Also, front right wheel... at over 30mph its making a funny whurring noise. not very loud yet, but definatly noticeable. Could this be the bearing on its way out? Or something else?
    Help someone PLEASE!
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    Re: Creaking
    if the whurring noise get's faster as you go faster or if the noise go's when going turning right at speed and louder when going left then most likely your right wheel bearing the creak maybe the lower arms try spraying the bushes and inside the ball joint's with white grease hope this help's
    Nov 2003
    At Home
    89
    Re: Creaking
    Rich,
    My A3 made exactly the same creaking noise last year, every time it was a really hot day.
    A bit of WD40 on the lower arm bushes did the trick.
    Hope this helps!
    ...Watching you!
    Earlsfield, London
    5,087
    Re: Creaking
    Excellent.
    Thanks guys. Will give it a go over the weekend.
    With regards to bearing noise(i think) ill pay more attention to it on my way home and see what its like.
    Rich [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    1,361
    Re: Creaking
    I'd go with X50 on this one, most likely the bushings on the lower arm or tie rod for the ARB.
